View Full Version : Tech / Misc
- Compression dropped! need help
- tranmission fluid capacity
- Engine Swap for a 93 civic hb
- Weapon-R Secret Weapon Intake
- 2 Questions Cams and Block info
- b18,b16 block difference
- Oil Cooler question regarding length of lines!
- F22B1 Valve Clearance Specs!
- 1986 honda civic hb??????????
- Question about YS1 Tranny?
- how do you read gear ratios??
- nitrous set up info
- Please help if u know about rods!!!!!!!! LOOK INSIDE!!!
- RSX air:fuel sensor
- Can an ECU be repaired?
- Does ITR rear seats fit in a 96 ek hb?
- please help
- whistling sound coming from under the hood
- Will my car still run if i bent my valves
- Poll: To "cat" or not to "cat"
- need help with emissions, EVAP
- car won't rev past 7000 rpms need suggestions
- Sequential Turbo?
- i need a link quick!!
- Valve Adjustment Problems
- Car won't start!!?!?!
- abs light on after shock install
- Need help. Coolant lines + more. Already searched
- Wide Band O2 Sensor
- Machine shop time and cost estimate?
- chaning oil on 00' si
- Starter problem
- HELP!!!!! OBD1 GSR ENGINE wiring harness
- Machine shop recommendation in south Jersey?
- Dart block, which clearances for bearings?
- p28 ecu chip's
- 2004 CRV Whistling Engine Noise At Constant 2500 RPM
- Rocker arm nuts fell off!
- WRX sound?
- need some help fixing a friend's car...help me out you techies!
- Funky starting problem... slow main relay?
- engine wont run
- K swap info needed
- wierd idle problem....
- changing fuel filter
- ls/vtec oil pressure switch
- TITANIUM ROD / brand and price please
- Is there a differences btwn a sohc and dohc Factory FPR??
- 99 si throttle bracket
- some smoke out of my exhaust...
- Wideband O2 sensor
- ITR disc/ CM stage 3 pressure plate
- Weight of flywheel
- advanced timing
- MSD 2 step with out msd box?
- Yet another question about some B16A history (Yes, I do have a fetish for it!)...
- 81.50mm or 81.75mm ctr pistons on b16a2????
- Got crank pulley bolt off! Pulley still stuck...
- OEM FPR Indetification?
- best way to clean injectors?
- D16Y7, VTEC head swap car won't start now. Please help!!!
- Help with Crank Pulley
- Alright, how in the hell do you CORRECTLY express torque?
- quick Tstat question
- Hub unit nut size??
- Again: ODB0 to ODB1 Conversion - One more question...
- Y21 gearbox internal in Y2 ?
- RWD Civic/Teg/CRX
- Are oil pump gears aluminum?
- Bogging down, hesitating, cutting off
- where to get your flywheel lightened??
- LITTLE BACKUP INFO ON DA9 TURBO!!
- high compression Piston question?
- question about replacing icm ( ignitor ) with msd box
- SRS Light
- Carbs on a b16?
- Help first time engine rebuilding. Need some advice for 92 Civic VX block.
- 04 civic si ecu ? (obd2 to obd1?)
- searched. tired. quick reply. Crank pulley
- Visiting a Shop in Califorina, Crazy cars, and Cool tech info too... 56k ehh...
- code 90
- moroso oil catch can install question.....
- ls head on b20 block efficient?
- AFC ll help for my ls
- Please help~! Injectors?
- Oil leak question
- how to you wire up pia fog lights i have model 1400
- abs acting up ... 94 integra
- oil in the spark plug cylinders.
- about how much hp?
- Beehive shape valve springs?
- Electronic Differential?
- ny state inspection!!!!!!!!!!!!
- Engine only firing on 3 cyl
- Extra Fuel? Fuel from nitrous line on stock injectors
- t1r grounding kit instructions
- Short Shifter is buzzing like a bitch!
- All Motor B16 video inside........
- No spark DEAD CAR
- Newbie clutch question-need help
- Vtec wont hit? searched
- "#"-Angl Valve Job?
- Eg hub question
- Need some feedback on my theory
- d16y8---------d16y7
- Exhaust manifold bolts on B18C1
- Vibration after Clutch/Flywheel Install
- Tie rod boots are torn.
- assembly lube
- oil preshure ground wire? black or blue
- Disconnecting Vafc
- proper steps for idle adjustment
- Removing shift linkage, can i drill out the spring/bitch pin?
- Can Anyone tell me where adjust the screw on the end of TB
- jdm d15b problem
- whats the weight of a 16x7 rota gt3?
- s80 tranns?? asap need help
- Rod bearing dilemma
- GSR crank in a B16
- speedometer doesnt work...
- who's making all of these rods?
- Valve Stem Seals Replacement
- tire mounting machine
- Tranny help! JDM B16 Y21
- Anyone installed Oil Squirters into an LS B18B or B18A Block?
- Riggin throttle cable on sheetmetal intakes w/ no mounting holes
- tach trouble Already searched haven't found exact problem.
- valves chattering
- Messed up Idle problem....No CEL
- delsol driver side mount on ek
- Car dies when I push in the clutch
- wiring for my alarm... need help locating wires...
- Can a battery change out blow up a Coil???
- Wiring help for my Mini me setup....
- h22 in 96civic ex have code 4,21,36
- Extra HP??
- Bogging problems
- HElP manually purging IACV in B16a engine
- ECU REPAIR PLEASE HELP
- where to buy OBD1 plugs and pins
- B20 resleeving. From 84 to 81!!!!
- drilling rotor screws
- d16y7 ecu on d15b7 will it work?
- How to pass emissions with a JDM swap
- Diffs....
- Knocking from engine bay
- Rare b20 P8R head question...
- ticking valves?
- D15b Dizzy questions....
- white smoke after swap???
- tuning question
- *Getting pissed off*- Need help!!!!
- Crank key sheared, damaged crank pulley and gear :(
- relocated battery what gauge wire
- Did my engine seize?????? :(
- how do u kno
- Alternator
- DC5R Gear ratios?
- D16z6 runnig dry for oil.
- What Engine do u prefer to put on your car?
- ecu chipping where? san diego
- AEM FPR missing vacuum hose nipple
- Post Pics of different ways to mount tachs in civics!
- Whats This LS/Vtec Setup Missing?
- Who sells flywheel contact plates??
- Wheel weight & acceleration
- hard line fitting question...
- Modifying centrifical advance distributor with lighter springs
- trackmasters in huntsville,al
- Stay with stock cams?
- LM-1 Wideband and Uberdata
- Fuel Pump/Fuel Pressure. Just a quick question.
- AEM EMS and switching between two maps with a switch?
- Welding diff on d16 question?
- Question about some B16A history...
- Help
- Alternato belt frayed, you think I can make it home?
- MSD rpm switch question
- Stripped banjo fitting on Venom Polished fuel rail, where to find new one?
- Help me ID this injector
- Can a distibutor effect mileage?
- What else needed with hondata.
- CTR cams installation
- Engine Rebuild questions
- how much longer my engine will last?
- crx si distributor on b18c1?
- B series distributor interchable?
- Starter Cut relay...Can I by pass?
- Serial number for Honda EPC ?
- torque spec for gsr rod bolts
- Head Gasket Question....
- any one using the odessy dry cell ?
- B20 in 94 Teg GSR?
- crankpulley
- Engine Rebuild & Storage Times
- can i use JUN 2's with just ITR springs and retainers?
- Which Hasport motor mounts?
- Help car wont start !!
- tuner advice
- fuse keeps blowing - wiring questions
- Cam identification?!?!
- Tranny leak, CEL 14 (IAC)
- clevite bearings HELP
- Uberdata/Skunk 2???
- Is the Defi D-gauge Air/Fuel compatible with PLX narrowband to wideband converter?
- CryO2?? does this stuff work?
- Need help with Honda starting
- F22 motor, D Series Trans, where can I get an adapter?
- rear disc swap worth it?
- installing A/F ratio and oil pressure
- Oil Pressure Light flashes at Idle
- installed new fuel pump, but has gas smell
- can anyoen spot the main relay...
- Power Enterprise P-VTC Wiring Diagram
- coolant hose to idle motor
- wiring harness question
- Is it my Cat or Something else?
- 00 Civic SI & DSM Injectors
- Muffler similiar to RS*R Exmag thats not restrictive?
- MC Reservoir - 13/16 vs 15/16
- obd0 - obd1 brake switch wire
- 98 honda civic coupe, what air intake is best suited?
- Timing gun with no dial....
- I cant seem to pass smog, how much fuel can I take out at idle safely
- D16y8 intake mani on a D15z1?
- Intake Manifold Swap...
- Can I use synchromesh in a tranny with a Kaaz LSD?
- block gaurd removal
- b18c5 and 4 lugs... can ya do that???
- Tune Up Questions
- GSR clutch... or tranny issues?
- What kind of O2 sensor is compatible with a 98 GSR?
- bad idea to drive around without inner timing belt cover?
- wires
- shot peeded LS rods
- What Would You Build For $7500 CDN????
- Honda Ignitor Question
- 1st time doing a brake job...should i leave off brake fluid cap while doing it?
- glo shift gauges?????
- auto to manual
- RC 440cc fuel injectors (Saturated)
- removing oil pump question
- Just curious.......spray angle of fuel injectors?
- help with auto vtec, yes i did a search first
- throwing out codes
- Shot Peening????
- valve timing
- how accurate are those air fuel ratio guages?
- idle bad need help
- Engine bogging when engaging gas pedal? Help!
