Anyone hd this happen(IGNITION)
Old Nov 24, 2003 | 05:46 PM
b18c1civic95's Avatar
Default Anyone hd this happen(IGNITION)
Around 4000rpm or so sometimes more or less, my tach will just go stupid. It will like jump around in its quest to catch up with reality. I had this problem before and it was supposedly the wires leading to my external coil. Now the car will sometimes die out with no hints or clues thats its coming. I will step on the gas and notice that its not running cuz the tach won't go any higher and if i do keep giving it gas it will backfire.....(Very loudly) It then won't start up for a while sometimes. I checked the wires leading to the coil and theres no signal so obviously it's these wires leading out. OR could it be the gray box that they come from inside the dizzy that has the flag terminals on it?? IGNITER?? Im not sure what that box/module is !? anyone had to replace any guts inside there dizzys'??? sound like a familiar problem anyone??? (This is a 95 Civic hatch with (obd 2 Gs-R/obd 1 ECU) i think it migt be where the wires are soldered together because if it were an internal part would't it happen more often?? Search was very helpful but nothing direct
Thanx-JOe
P.S.> i would hate for this to happen under boost !!!! so Im waiting
Old Nov 24, 2003 | 06:22 PM
mmuller's Avatar
Mad Scientist
Default Re: Anyone hd this happen(IGNITION) (b18c1civic95)
sound like ignitor, make sure the wires are tight
Old Nov 25, 2003 | 08:37 PM
Default Re: Anyone hd this happen(IGNITION) (mmuller)
Alright
DamnThatsRexy
May 26, 2013 10:02 AM
Geiro94rs
Nov 11, 2004 11:01 AM
SpoolnG2
Jun 26, 2004 03:55 AM
turbo sol
14
Dec 12, 2003 01:30 PM
