View Full Version : Tech / Misc
- noise in head, what could it be?
- Problem with tranny.
- What ecu to use with b20/vtec swap?
- hesitation/ lurching/ misfiring/ bogging @ hwy cruising - new hondata s200 user...
- Bad Piston Rings?
- What do you think of this setup??
- Temp gauge degrees range
- which springs are best?
- o2 cx wireharness
- Getting my DX past 93
- rear engine mount bracket problems?
- ecu question
- CKF Sensor CEL Code??
- DPFI to Mpfi
- Problem with a clunking noise coming the driver side when applying brakes at low speeds I don't know
- Test only smog hook up... (Bay Area)
- did swap and doesnt swap
- Detailed intructions on how to replace valve, headgasket?
- Tuning On Long Island
- Uberdata help???
- hondata and ecu problem
- ITR throttle body on GSR
- CTR & ITR Steering Wheels
- what's the difference between an oil catch can with a breather filter and without?
- Head Defination # on G1/G2/G3
- second intake runner in plenun open 24/7..bad?
- Problems with the Honda and can not find a solution.
- i got a problem with me civic hatch TRUNK Help please
- Limits of b-series fuel injectors
- Front wheel drive - rear wheel
- Head stud install, Two pulled threads out of block, HELP!!!!
- SOHC Compression Gurus, Who Knows There Stuff
- omni power coil overs??
- 98-01 accord 4 cylinder head bolts torque specs?
- My spark plugs have red spots on them
- motor bogs at any open throttle??
- Where to get MTF on Sunday? (dealership not open)
- when does the cam sync on hondas?
- cam sprocket?
- obd0-odb1 conv. question.....
- Need Help With V-Afc2 and S-Afc2!!!
- Wideband Questions
- HX operating ?
- Safc-II Display color??
- need expert help quick
- question about cams.
- Massive Loss of power at end of 3rd, help needed!
- Hondata S200
- installed skunk2 s2s1 but having a couple problems
- Brake pad identification help
- preloading coilovers....
- Anyone replaced the 5 hard lines that run underneath an eg?
- discovered something regarding my oil consumption... any ideas welcome
- Need A quick answer to a question please.... Suspension Techniques Q.U
- Kind of Confused about SS...
- energy susp. red or black?
- sensor digram
- head gasket leaking but not overheating
- Discussion:Flywheel
- koni yellows
- what to tourqe cam plates to
- remove the motor for new pistons/rods/bearings ??
- unconsistant power
- small bet with a friend: ENGINE MODS POLL thank you
- radiator???
- 99 accord ?
- hit big rock, bent some things, need advice on structure
- b18c5 overheating
- Omni Power HELP!
- which color seats came in my white integra?
- just installed used 97 tranny, clutchmasters 4, soft pedal ?????
- profec-b-spec2 programing problems
- installing pistons check list.....
- need help on torque spec for ls crank in gsr block
- Are DC Sports headers really worth the money?
- Zdyne Gold SECU serial cable wiring
- Buddy Club P-1 Racing Wheel SF
- hesitation/stutter on slight acceleration with b16a crx
- Which one is better (b18b or b20z)
- itr manifold vs. skunk manifold
- Leaded gas, will it harm anything other then your cat?
- b16 in coupe, thermostat didnt pop, bad?
- AN-R Intake Manifold Gasket Leaking...anyone else??
- Cold lower radiator hose?
- H22 in 92 civic hatch
- PLEASE HELP. Need my window rolled up.
- Tuning on low comp D Series...
- WHY DO PEOPLE KEEP SAING GSR IS BETTER THAN H22
- Stripped my thread!
- bleeding air out of radiator
- can this be done ?
- dead cylinder, need help
- Piston slap on H22a?
- what springs are stiffer the h.tech or the s.tech tein springs
- This is way out of place but hey...
- Buddy Club coilover
- can a auto firewall harness work for a gsr?
- another emissions Q....
- I need the ECU codes!!!!!!!!!!!!!!!
- This for a friend of mine ( back firing threw the throttle body)
- When to upgrade head? Forced Induction, Built Motor
- **Need Help ( PICS INSIDE )**
- B16a timing belts
- voltage drop(anti lock light flash, cassette player stop) when apply brake
- CEL passed diagnostic test, why?
- has anyone been to sgt to get there car tuned
- oil filter is empty on ls/vtec? help needed!
- ? what to do for next mod upgrade
- anyone know how to install pr3 pistons in a gsr???
- b18c and b16a fuel pressure regulators
- D16z6 Distributor Wiring
- NEED HELP FOR EMMISIONS
- can anyone identify this differential?
- Need help with rc 440 injectors a.s.a.p going to the dyno soon.
- Anyone ever had APEXI VAFC problems? shorting out / not saving settings?
- ignition upgrades on a high cr high hp n/a gsr
- bent part rear disc swap
- wideband & narrowband o2 sensor
- obd2 wire harness with obd1 motor?
- ITB question
- b20 vtec fuel problems
- weird sputter???
- ls vtec
- Does anyone have pics of all the crx grounds?
- Fuel System Cleaners
- H22a header compatible with an H22a4?
- '00 Integra wont turn over.
- At what point are my axles in danger (drag radials) ?
- Honda Tech Stickers!?
- converting hondata files to uberdata? possible?
- Need help converting Spring Rates (kg/mm)
- Engine Building Guide
- 95 Accord EX intake/exhaust valve gaps
- Civic disc brake conversion question???
- cleaning up a new flywheel.
- Stronger Oil Pump Gear - Is it Needed?
- setting timing??plz help
- are type R valves a cost efficient upgrade?
- bearing colors= what letter on hondas website???
- Swap Finished, but one problem
- About MSD Ignition
- what valve cover will fit?
- WFT ???? (help)
- Best Brake Pads?
- input shaft question.
- Spring rates of Neuspeed Sport Springs vs Ground Control Coilovers
- Low rpm vibration..axles?
- what part # for side marker lights from honda?
- chh chh chh bang??? not firing up wtf?? need help
- Difference between long and short block B16's.
- B8/Z6 CR?
- Where does the radiator hose go?
- ecu
- CRX Guage Wiring Experts Needed!!!
- Speedo noise
- car just shiut off while driving
- car running too cold?
- car starting is wierd..
- Exhaust Manifold
- car doesn't heat up when first started; what could it be?
- How to adjust stiffness on Apex N1 coilovers?
- Where can I find the VIN on a B18C1?
- Professional Suspension Tech needed in the NJ area
- Question about grinding valves..
- HONDATA tuning shoppe south florida?
- parts list required for a build up of b18b other than rods/pistons
- H22 Turbo with Honda 200
- have a turning isue with the Type R
- NEED HELP D-series CODE 20
- Starter keeps going out need help!!!!
- Do a D16Z6 and turbo it or H22???
- what settings should i use for my vafc. all motor..
- tranny question.
- torque wrench...
- Electrical Problems
- need some help
- cleaning cone filter?
- ABS light on??
- Can a Civic EX tranny be install on a Civic HX??
- b20/vtec question
- Compression Ratio
- Civic SI 99-'00 brake calipers fits JDM EF8?????
- harbor freight $69 press for bushings?
- DNX Coil Over Kit
- ek to eg springs
- NEED help with my motor, Revs at 3000.
- LS/Vtec VS H22a
- brands of hi flo cats
- fuel flow rate gauge
- Civic 99 SI(r) tranny + JDM R LSD ??? is it possible ?
- QUICK QUESTION! WIRING IN A CRX SI PM6
- After market lsd clicking.
- HELP!!!
- how many sensors do obd 1 cars use?
- ls vtec build up
- Help with tranny problem, wont shift into 5fth or reverse
- which is the clutch master cylinder
- What kind of engine?
- rear wheel bearing install (done hopefully)
- Air Filter Questions
- Car Bogging?
- electrical issues all of a sudden...
- GSR/LS connectiing rod big end pic request
- cable to hydro conversion on my crx!!!!!!
- my dyno sheet...
- Engine Troubles, please help
- :thumbup: MINI ME QUESTION D16Z6/D16A6
- need help
- I did a search and I need the Measurements for LS and GSR Crankshaft....
- shards in oil after cam/spring install
- Speedo jumps around after car has been running awhile
- Any way to *better* my OEM 'traction' bars on my integra
- OEM ITR LSD
- weird high idle (2900rpm even when warm)
- Bad VTEC Pressure Switch Cause Low Oil Pressure Reading?
- Wires interchangable?
- How do you set cam gears to zero?
- which way do pistons face in block? valve clearance cuts in piston
- Tip in isses w/ 3bar cause by placement of vac source
- ECU identification - is this correct?
- B18A Tranny with B16A2 Motor?
- HELP! DON'T KNOW WHICH WAY TOP PISTON RINGS SIT!
- Bad Crank/Bearings.... what are the signs? ASAP
- checking tranny fuild
- JUN cams Vs. Stock rocker arms=total destruction.
- What used to cut ROCKER out?
- ARP rod bolts
- rod length formula...right or wrong?
- question about hondata s200 and p28 ecu... (zif???)
- 92 CX 1.5 motor into a 93 4dr LX??
- GSR p72 ecu
- High idle problems!!
- what is the power loss if any?
- compression test results for high compression sohc vtec-
- piston to deck height, alittle complicated...well for me
- do i need a new fuel pump?
- feilds controller
- Rock hits AC condensor - everything leaked out - now AC is warm
- Jic Magic Strut tower bars?
- Will a GSR Oil Pan bolt up to an LS?
- quick help please
- crushed dc 4-1.. doh
- Motor techs plz helpme figure out my compression, its alittle tricky
- Field SFC wiring o2 wire goes to primary or secondary o2?
- Valve Cover Studs
- Would someone please post wiring schematics for h22a and h23a1
- Does vtec not work if Ecu goes into limp mode
- DH-Racing Pulley PLEASE HELP!!!!
- whats high flash point solvent?
- main cap bolts
