View Full Version : Tech / Misc
- second gen jdm b16a problems
- A/T Line Identification pic
- head gasket
- Anyone have 96-97 accord parts for sale
- need a little help
- Does a6 TB match z6?
- My obd1 D15b makes a bov sound? Input?
- Coilovers.
- yonaka intermediate shaft
- 91civic alternator issues with amp n sub
- Motor Mounts
- Aeromotive FRP won't adjust
- What is a compression test?
- Transmission Fluidk
- NRG steering wheel install help
- obd1 b16a swap into da integra having a problem
- car wont start
- automatic transmission temp sensor
- Distributor Timing?
- 05 tsx dome light
- wire worx "wire tuck in a box"
- HELP 2000 accord rear tyre wear
- Making my custom exhaust, any suggestions?
- CHROME PARTS!!!
- piston ring
- oem vs aftermarket coil
- 93 civic ex turning over, but won't start.
- Help!!! h22a dohc vtec how do I run vaccume lines!
- Bought a cheap header...
- How to wire shift light to stock tach.
- honda meet closer to oregon
- CEL code 41 and pulsing idle
- I need help can anybody help me with my 99 Honda Accord
- Head bolt Heli-Coil
- '90 Integra Exhaust suggestions please
- Thin Wrenches
- Switching rev counter and speedometer on EM1
- sometimes car wont start after a 10-15 drive
- serious issues
- Relay between the power wire for fuel pump?
- have you ever hack sawed through a CV axle?
- Please help me 93 DEL SOL
- is my vtec working (with soundclip)
- Injen intake and filter
- D16Y7 skunk 2 intake manifold RPM jumps
- my car wont start! help!!
- Integra gsr timing
- Fabbing Coolant Overflow Tank
- Apexi Turbo Timer, HELP
- 96 gsr stock backfire died now stumped help please!
- New B series transmission rebuilt/overhauled?
- smoking b16 help
- oil pressure sensor location
- Looking for Time-Sert Kit 4160 for D16y8
- No heat 96 civic
- How to post pictures...?
- Dash light hesitate to come on! HELP
- How do you replace 92-95 civic dash bezel?
- jdm h22 swap in a cd5 accord need help please
- Vtec lag/sputter
- Timing Issue (b16 JDM obd0)
- another ek map sensor issue
- Cooling fan stays on when key is "ON"
- Fuel Gauge.
- JDM ecu socketing, cant get it to work
- Z6 head swap cuts out around 3200rpm
- Weird noise: wheel bearing? Axle? (with video)
- B18B1 off a tooth after timing belt install?
- 97 Honda civic problems help
- OBD0-OBD1 Conversion, Crank but no start!?
- No power to fuses under dash
- JDM Volt Gauge
- 97 accord flooding, won't start
- need help Euro R h22 civic
- 2000 civic b18b swap need help
- 92 eg hatch wiring question
- 92-95 si hatch build
- Where to buy gears?
- Aftermarket Temperature Gauges - Defi / Aem - What type of temp element ? signal ?
- right rear turn signal takes 5 minutes to start working
- methanol spark plug?
- 1999 accord 2door LX (ULEV) catalytic converter and exhaust
- jdm wngine harness to usdm?
- B16a2, OEM headgasket, dowel pins don't fit through headgasket?
- No PCV on my b18 swap.
- 93 Civic Slow oil pressure build up
- dizzy help with obd1 conversion
- How to repair crank keyway
- obd2 iacv problem?!!
- Voltage drop at injectors- HELP! :(
- Help on upgrading sohc civic dx
- 85x89 burning oil or running rich?
- HAVING TIME OF MY LIFE REMOVING CRANKSHAFT BOLT
- Valve gap on b16
- **How to Choose the Correct Gauge Wire**
- Difference between auto. transmissions?
- Honda over heating
- Brother's 94 Cx Hatch tranny noise
- o2 heater circuit malfunction
- fake carbon fiber interior removal!
- Recaro Baby Seat
- I need Hep
- Wiring Help
- Strange Oil leak...need Help...
- blox expansion tank install
- delsol exhaust. need some clarification
- 89 crx si d16y8 3500 rpm limit HELP
- B series question help please
- Need help with seat rails?!
- Re-wire Ecu
- Compression too high on h23a
- Stick Rad Fan, Prelude 93
- Ls head tq issue. Question inside
- B20 vtec turbo issues - head gasket, rings, or cracked block
- 95 Civic Throw out bearing?
- Bseries mount question
- Intermittent loss of low end power
- Is it possible for Vtec solenoid to be bad?
- how to tell the differnece between and auto and 5 spd ecu?
- How to test ignition coils
- INFO on: 96-00 civic Apexi power intake
- Honda Civic Misfire
- Distance from valve
- AN fitting questions
- question about a clutch
- crack in CYP sensor
- Compression Test: Weird results. Wet & Dry
- P61 bad Q10 transistor were to find new one?
- honda compression
- OBD0 Remap for Boosted D16A6
- Help please!! 94 Civic overheating
- idles perfect, rpm does not drop, or even goes up to 5000rpm itself between shift
- Small Alternator?
- NRG quick releases interchangeable?
- Rmove fuel from OEM fuel tank?
- rpm/speed activated solenoids
- S2000 Engine Swap Help
- Urgent! Cooling Systems Screwed
- Honda fit automatic climate control conversion
- Fuel pump will not prime.
- ecu question please help
- b20 swap info please help
- Please comment on my exhaust set up for my EM1
- Picking up a '00 Integra - What tools to bring?
- Need help with 99civic jdm gsr not turning over
- Type-R rod bolts differ from B16?
- Spark Plugs
- Another boot leak.. inc video
- What rod and main bearings do I need
- '89 JDM B16A first gen VTEC solenoid leak?
- <<<<All motor D16 outrageous fuel pressure>>>>
- Engine Loses power after hard turn
- 2000 civic EX swap advice please
- Del Sol won't start
- custom steel intake manifold input wanted.........
- What cools best
- Advice, Please? Civic SI 2000
- Overheating HELP!!!!!
- H-series Break-in Question
- 97 EX Cat vs. 99 Si Cat
- OBD1 CEL #9 Help For 94 Integra b20/vtec
- 91 integra engine harness
- Torque or horsepower?
- turbo timer issue
- Gear ratio help
- Ignition issues after unknown pop.
- Bugs after swapping poor mans ITR
- Throttle Body Boring and Plate
- Evap 0497 code help
- Driving in the rain without a hood?
- ARP b20 rod bolt question
- ebay tri-y replica flexpipe and cat
- Fuel Tank
- no running lights
- Help with Idle probs. already replaced IACV and bled coolant...
- ENGINE BLOCK INTAKE MANIFOLD SPACER
- Is it ok to short + and - battery cables
- 2002 acura mdx,disable lockup converter
- Using a CRV gearbox for RWD?
- Karcepts EHPS line
- Cam Seal Leak 2000 SI?
- B16a IACV Gasket Compatibility
- Low Power, Surging, Sudden Hesitation below 3000rmp HELP!!
- just brought a ek 4dr with b16a
- Newly built b18 block - turn over by hand, not quite right? - video.
- Find camshaft part number
- magnaflow/flowmaster exhaust
- oil pump install 98 prelude
- timming marks dont line up
- D to B
- Problems interpreting a Leak down test
- Not firing on cyl No. 1
- Ignition Timing and A/F ratio...
- ID injector fitment
- JDM swaps in Cali. Good idea/bad idea?
- H2b Swap HELP (EK HATCH) + LOW STANCE
- B18C trouble - power/idle good, lots of smoke!
- need help with spark plugs
- ANy companies make 83mm off-the-shelf pistons?
- axle removal
- ISO: Diagram for vtec-ecu wiring 94 prelude
- Builing a 94 prelude type s. any ideas?
- Help how do i wire my vtech to my ecu??
- Piston question.
- Part out vs sell?
- Integra Type R Cluster
- Ef wiring problem??
- Del Sol Cabin harness
- 1999 Honda Civic EX Auto Distributor Question
- Gsr oil pan warped!!!! Help
- 94 civic ex crank pulley bolt
- injector size identification
- H22a1 crank, but no start :(
- Want to turbo my mini-me but dont want to blow it up
- Intermittent shudder/bog/stall - Integra
- Stutter & Stumble while driving
- Vtec Spool Valve
- Is this a GS-R crankshaft i have?
- injector and emmisions issue?
- Oil Filter Tech
- Muffler replacement
- Passing Emissions
- Torquing GE head studs - lube
- OBD0 to OBD1
- 96 spec ITR longblock?
- Gsr starter problem?
- b18a1 timing belt question
- Accel Replacement internal coil
- 95' Eg Hatch Idles Weird??
- throttle body and intake manifold
- Skunk2 Pro 1 Cams
- what does the ICU integrated control unit do?
- b20b jdm automatic full swap into a Ef 91' auto. will it fit?
- Will a Civic FD 3 spoke steering wheel fit an EG/EK
- what can cause a cam to break?
- 99 civic si head gasket problem
- Weird Vibration In GSR DC2
- SRS module replacement help
- 98 gsr wont turn over
- swapping b16a into da integra questions
- motor mount bolts EF vs 92+
- iso b20 builds
- No dash lights and shifter lock will not disengage
- Hid high beam ballast troubles
- Honda engine measurements and weights?
- after installling MSD 6AL car misfire at 4500RMP and up
- alternator wont charge my battery, but why? need help asap.
- WHATS WRONG WITH MY CAR?! HELP!
- k20 del sol ecu?
- ex cluster in a dx hatch gauge issues
