View Full Version : Tech / Misc
- Tapping knock sensor on LS/Vtec???
- what head gasket and timing belt will i need for a gsr block and a b16 head
- what vss do you use w/a 94 and up gsr cluster, need your help asap
- what are better cams for the street (skunk2 st. 2 or crower st. 2)
- crankshaft bearing part numbers? - B20B
- ES Oval Mufflers Need info.
- What with this Trial User stuff????????
- Why am I burning so much oil...?
- bridgestone potenza S03's only $80 at tirerack
- help with Greddy A/F Gauge...
- how do u put oil squirters in a ls block
- GSR front brake swap; worth it?
- V-afc problem
- h22 in eg...
- Tach's
- Clutch, tension and rubbing noise?
- anyone used CP Pistons?
- Possible reasons 1st and 2nd gear are tough....
- My spark plug electrodes look like there white. Ignition timing off?
- Difference in Dyno?
- idle prob
- p75 rechipped for vtec??
- Quick question, 92-95 Civic & 94+ Integra....mech or electronic speed sensor?
- Purpose of Oil catch can..anyone??
- integra idle problem
- Anyone with an aem ems and N/A engine?
- Cosmetic and Performance
- Anyone using Fightex coilovers?
- Changed axles, tested motor, tightened EVERY DAMN BOLT, but to no avail
- Benen Fuel Rail Port Sizes
- Can I put a 90-93 AUTO final drive in 90-93 Manual?
- Best way to degrease a motor
- hey turbo ls guy's
- where should i place the weld-in fitting... and more guage ??s
- Compatable transmissions on a D16Y8 engine...
- are there any turbo kits that i can get for under or around 1,000?
- b20 bottom end or bore ls bottom end
- IAB Secondaries/Cam timing for possible gains
- Why cant I reply in the classified area?
- how do you know if it's an itr cams and not gsr cams or b16a?
- no ignition power when key is on
- ATTN people who know stuff about the ZC tranny
- Magnacore wires?
- Car Rolls when parked While in Gear
- VAFC and bad O2 sensor!
- Valves springs for B16A2
- ls/vtec with ITR head
- B18C in my 93 ls teg
- chart for electric oil press guage bypass..?
- Trying to located the right main and rod bearings i need
- Has anyone ever hooked up a greddy elect water temp guage??? help please
- Help Throwing a code
- rpms
- hondacrx.org down - shift light schematic?
- What else should i order with my CTR or ITR cams???
- idle problem
- fuel pump main relay
- Bad axle or bad ball joint
- CEL 76???
- Could you tell me the difference between a cable and a hydraulic tranny?
- can someone please help me in the sacramento area?
- stock EX engine capability.
- eagle gsr rods in ls block
- 98 lx sedan Auto to Man .Conv. Need info.
- Skunk2 Camber Noise
- ExtrudeHoning
- WHEEL/MAG question
- How many cars take 4x114.3?
- which chip for CTR cams
- H22A Intake Manifold w/ 4 Runners
- Battery or Alternator
- civic wiring problem
- Is this head fixable??
- water injection
- How much should a shop charge?
- B18C1 Cams best for which applications???
- How
- Camshaft break - in procedure HELP!! need advice!
- A/C thread please help!!!
- Valve adjustment clearences!
- Anybody know what brand makes a badd asz ecu for b16a2(99-00 honda civic si)?
- Distibutor Problems
- CEL on N2O...
- Key cylinder replacement
- fuel filter?
- Water Wetter?
- How much should i advance timing?
- Can my block be salvaged? (pic inside)
- Having trouble with my carbon fiber hood?
- GSR turned LS....wtF?!?
- Cx tranny or ex tranny, Built d16z6 or buy jdm d16b6
- causes of hot cylinders or extremely lean condtions?
- Camshaft break-In HELP! oil synthetic to reg. dangerous?
- pulling off head-drain coolant?
- Changing Headlamps
- What is the BEST street tire??
- VSS and other sensors
- need help going from auto to man thanx
- fuel pump?
- Exedy clutch feel
- 1st Gen alternator problem, I think
- gearing questions
- where can i find website with info on b series tranny final drive ratio????
- Rod Length/Ratio - Iskys opinion
- what size is the rubber breater hose?
- i need a doc: symptoms of a bad brake caliper
- Rough start in mornings.
- pics of rethreading of block
- OBD II Type R and GS-R Distributors compatible?
- ECU's on ebay good buy?
- oil guage question
- @%$!*& Injector O-ring Seal
- 2000 civic ex auto to manaul problems *idling issue*
- Help me Please!!! Misfiring problem
- never go to sears for work
- draining antifreeze yes/no?
- Skunk2 ECU?? all sensors function??
- Accidentally seperated knock sensor
- Vavle Spring Compressor Tool. for use on a B-series head.
- Headlight Adjustment
- question about type r cams. and ohio guys please look also
- GSR tranny overhaul, options/suggestions?
- B18C spoon engine
- crank case...tech question - help!
- Getting CTR cams for GSR need some help on things needed!!
- piston to valve clearance on b20 vtec with b20z pistons
- Minor B20 bottem-end build for 'peace of mind'..what else do you reccommend?
- Resurface or replace rotors?
- Wiring HArness, I need a new one!!!
- Integra/Prelude/CIvic Brake Master Cylinder sizes?
- Carbon Fiber Brake Rotors
- how much?
- how to change timing?
- playing w/ fuel pressure....
- Bay Area People... Where should I get a Turbo install Cheap/Reliable?
- mystery motor problem, somobody help me......
- best parts
- nasty cat rattle.....and NO it's not the heat shield!
- B&M fuel reg.
- Can you guys interpret my alignment report?
- timing belt keeps breaking???
- A good way to test sidemarkers?
- accord lx cam install help
- Clutch Switch Bypass
- OBD0 or 1?
- Why does my tach twitch?
- rpms jump to 5k when started up..... please help
- Vtec Troubles
- b16 cylinder head ??
- LS/Vtec With GSR Head
- SMS Cat Problems..............
- What compression test numbers do I want?
- Locate the main relay on a 90 crx?
- ls/vtec
- Resleeving, need some advice
- hondata ecu
- fuel pressure regulator
- IACV vs EACV ... are they the same?
- Relability?
- How much $ to resleeve/bore a b18b?? And what about oversize pistons for N/A?
- What major components control the idle?
- How long can tires sit for before 'going bad' ?
- D series build up's
- Powered by Honda.....
- transmissions help........readdddd
- Valvelash specs for Y8 head?
- Question on MAP sensor
- KATMAN? obd2 static ignition timing question
- Collectiveracing.net
- slotted brake rotor
- Auto Window problems...
- type r exhaust
- Need fuel help 2
- How to Remove Broken Header Stud Bolt
- s80 and y80 tranny
- whip head
- 98 ls motor in a 95 ls
- Which MSD distributor cap on a 98 Integra LS?
- Leaky Distributor
- broke my car/clutch...need opinions.
- how many degrees is each mark on an AEM cam gear?
- exhaust components
- is vafc hard to install??
- ***any0ne squeezing???***
- type R piston w/ b18b head
- PLEASE come check out my story and help!!!!
- Where can I find O2 simulators?
- Ground Zero Motorsports Video for 2002
- found a site that sells CHEAP jdm motors
- timing belt tension question
- 3rd Gen Integra A/C Removal
- 3" High Flow Cat?
- DIY Vtec controller?
- What sensor is this ??
- Dynojet A/F ratio readings
- Can you use a B18 block with a B16 head?
- Sparke plug replacements...
- stroker theories?
- Suspension rumble
- Limited slip on my ITR
- 93 ls integra
- B18A what is the REAL displacement?
- Does a 96 JDM ITR P73 ECU look for secondary 02 sensor?
- HELP build bottom end will not turn over by hand
- Type R pistoNs in B17a block Help!!!
- just got a 00 h22 engine, but need some quick info on the skunk2 harness.
- question about insurnace for gsr and ls
- Anyone with CARFAX unlimited account that can help me out?
- what do you guys think?
- milling the head 11.0.1 pistons
- thank you mista bone
- another good link for engine codes, chassis, etc.
- Enigne Rebuilds (Costs)
- how to do a compression test?
- Darton or Golden eagle
- H22a revs to 6500, but no CEL codes!
- What size?
- Look at these spark plugs...
- auto to manual on h23a
- Electronic timing retard question
- Adjusting TPS?????HELP??????
- short shifter help
- motor help, got a question...
- 404's non vtec review
- WTF does this mean?! OBDII insanity
- Anyone using AME (Art Morrison) rollcage for 96-00 civic coupe?
- where to buy.............
- Exhaust manifold gasket
- battery question
- Is 5-10lbs of torque REALLY that big of a difference?
- Best Springs For Koni Yellows?
- 93 Accord Aerodeck ABS
- Does any one know how to make the str drag maxx intake manifold work correctly on 99 honda civic si?
- b18b question // please reply
- head bolts
- vapor jet thing?
- d16a6 exhaust rockers shot?
- compression test results......not good
- came across a couple problems while tunning
- Engine Bay Pics Thread
- timing for 95 civic dx
- Is there any way to check the VSS?
- how to tell spring rates on skunk2 coilovers by # on them?
- emissions testing
- whats the easiest way to relocate battery to the trunk
- DOHC ZC EACV & idle problem, need assistance
- checked compression, check it out!!
- Which oil is best for my engine swap?
- toe in/toe out, oversteer, understeer?
- coilovers...yes or no
