View Full Version : Tech / Misc
- type R lsd and gsr tranny?
- LS-Vtec to B20 Vtec...
- Wiring issue help:
- Timing belt change. TDC issue.
- How to tell LSD with transmission out of car
- h23a1 swap
- diff going bad?
- Coolant press fitting on skunk2 manifold loose (need input)
- 20MPG How to Improve suggestions Please
- Oil for braking in motor
- new dizzy cap and rotor?
- Rethread
- GSR oil pump failed....question about crank
- What lsd is this?? Searched
- is this a sign of a bad tps???
- Bolts that goes behind the block
- Clutch Problems/ Engine Bogging
- Stiff gear lever (auto) in D,2,1
- Need help ECU error code 15 - emergency, read!
- my tranny is goon need help...
- Did search, Hondabond used on headers exhaust gasket?
- what is a layout guide for rebuilind a 1.5L engine
- b16 cable trans rebuild
- Someone please solve my problem, n00bness inside.
- Tach, fuel guage, temp guage all not working...fuse??
- Liquid OIL coming out of exhaust
- Car Idles at 2500 - Need help!
- hub, quick release, steering wheel= no horn???
- ecu chipping question????????????
- Increasing MPG with aftermarket upgrades.
- no power on fuel pump help me
- need help.
- K20b Honda Engine equal to 1AZ-FSE Toyota Engine?
- NEED ADVICE ON WHICH BOTTOM END TO GO WITH
- ls crank in gsr block
- can i get some help please?
- saga racing gauge questions?????
- aftermarket part number for 91002-PS0-003 input shaft bearing?
- Replaced tie rods and atts fluid- now no start
- Who makes the best connecting rods?
- pm6 si
- ODB0 ECU Starts Car with ODB1 Ignition
- all motor valvesprings and retainers on a boosted motor.
- transmission Help please
- If i were to build my top end. What should i do 1st and why?
- what size throttle body should i buy
- S300 in a P28, help
- 2003 Civic EX Transmission/Electrical Problem
- Password JDM mag oil plug issue.
- B series engine choices?
- NEED FACTORY WIRING INFO 92 CX DASH SIDE!!!
- obx lsd for a ys1 which unit are you using?????
- ATTENTION RYWIRE
- ls vs. gsr
- S300 now VTEC sounds non existent?
- d15b coolant hose housing
- wierd power loss...vtec works, fp is good....thoughts?
- d16y8 tuning question
- Rocker Shaft help
- Funny Noises
- Car bogs, Innvovate WB
- Need advises for b18b tuning
- Belts Squealing
- IACV Block Off Plate
- skunk2 throttle body
- Dumping Oil
- 90' civic ex sedan fwd a/t to 4wd m/t ???
- D15b timing belt and water pump part numbers
- FAL Flexite rear-half windows
- gas stations with racing fuel
- Why my new timing belt skips????
- Should I or Shouldn't I?
- buddy club lug nuts
- What are forged pistons?
- Can i Use my ls oil stick in my gsr?
- Hondata s300 help
- code 13 and 17 help
- Is this a useful engine related idea?
- code 21 vtec
- Distributor Came with MSD Cap... what to do.
- is there another engine compatiable to acura legend 95 type 2?
- Help identifying injectors
- Transmission Gear set treatments....which is best?
- Type-R cams in 99 b16, worth it? And need valve adjustment?
- clutch problems
- JDM D15B
- Some Minor Problems
- IACV Woess
- B SERIES HEADS!!!!!!!!!!
- jdm Dohc f22b
- Will a Y7 Oil pan fit a D15b2 block?
- SAFC2 Hi and Lo settings not working!! need help please
- Fan not working b20 motor on 98ex
- Do you trust your shift light?
- Odometer help!
- how to replace a 8pin plug with a 9 pin plug
- Any differences between b18c1 and b18c5 crank pulley? **searched*
- halfshaft difference
- torque settings for f20b blue top
- Convert obd1 to obd0 b16 dizzy?
- how can you tell manual from auto halfshaft
- how can i tell if my trans is a b16???
- Universal fuse block?
- p72 obd???
- buying a used engine? paperwork? what should i get in order to prove its legally mine?
- Will this work for fuel pump testing?
- Engine swap!!!!!
- Is an Idle Control Valve needed?
- new to honda...accord 08 piggybacks/chips?
- OBX LSD making noises at slow turns (i have searched i have diff sound)
- LOOKING FOR OPINIONS....
- belt burned smell under the hood
- very small persistent fuel leak- B18b fuel rail
- Wrong crankshaft??
- Input shaft bearing problem
- new built motor question.
- Buddy Club Spec II
- Timing failed during smog inspection....
- Headlight Problem
- Need Help, Quick question................
- Difference of JDM and USDM ITR throttle body
- h22a1 97 engine problems
- help quick!!! what is wrong
- Need 93 si engine wiring diagram! Searched!
- what kind of spark plugs can I buy over the counter at any auto store for my built h22 turbo.
- Is there a non-subjective way to tell if a ball joint should pass inspection or not?
- 94 Accord: Low idle when A/C is on, air conditioning stall, rough, "searched"
- 1990 Civic LX 1500 A/C blows warm / intermittent clutch / loss of 12V
- need help with these ge headstuds!!!!!
- Ignition Amplifiers
- SKUNK 2 CAMS AND SUPERTECH VALVETRAIN
- which one is it? 600 hp or 300 hp?
- Notching single cam block
- Engne torque damper??
- Competition & Classification running E85
- New type r transmission from Acura
- Quick question???
- Best Transmission to Use, Del Sol EV Conversion
- Discussion on Premium Gas for your car - again
- gsr head cam oil clearance *experience needed*
- Radiator coolant
- B16b question
- Fresh motor, first start/drive/break-in, car bogs really bad, idle horrible
- strange noise stumping even honda gurus, need help
- Ls crank
- ac install in 92 eg and it wont engage clutch
- transmission fluid....
- b16 vs. gsr
- K20A Throttle Body.....02-04 same as 05-06?
- Car only starts with MAP unplugged? WTF!!!
- CEL problems, suggestions please
- Looking for Honda mechanic in Las Vegas area!
- 2003 S2000 CEL
- cam gear timing on turbo b series
- coolant temperature sending unit
- do I need new valves?
- How much horsepower can a stock honda trans hold?
- How Honda part numbers work
- Idle Problem
- Momo steering wheel hub... does it allow you to retain the thing that flicks your turn signal off
- Anyone ever see this about mobil and valvoline???? is this true
- Type R Cold Air Intake
- Battery and Relocation
- Tool/s To Check Bore Size + Stroke Perhaps?
- Difference between CTR and ITR cams?
- which retainers r the best
- so how many of you drive around with an open velocity stack daily?
- Will obx lsd fit a s4c gearbox with a 4.928 FD
- Distributor problem. Electrical spark type noise...
- High Revving Forced Induction
- finding part number on type r crank
- how do electric cars work??
- obd0 to obd1 wiring
- Oil leak/spray at high rpm's
- bad compression ls/vtec
- lsd problems.
- Why can't a car always be in Closed loop mode?
- Nick in head surface. Is this deep or....?
- need to lube my power windows
- b16a swap
- throw out bearing noise after brand new one installed
- b16 in b20
- Replacing head gasket, dowel pin question..
- code 14 help !!!
- Y8 swap into 91 si hatch....any info would help.
- Breaking up above 6,000 Rpm
- h22 tranny fluid???
- limo tint removal help!
- Vibrant Catalytic Converter good for smog?
- can a P73 be used with Hondata?
- H22a Problem
- bad compression?
- P54??? Help!!!! Need Info Bad!!!!
- To much compression and coolant overflowing
- Pinging/Detenation, B16a2 searched
- gauge cluster
- CLUTCH HELP, solid disc, or sprung, 4 puck or 6 puck?
- Aftermarket CV AXLES?
- IACV problem, 96 civic dx... no code w obd2 LS ecu but code 14 with obd1 LS ecu
- Camshft turns?
- 2000 EX Civic- Stick, Input Shaft bearing question.
- i need a trans
- Are all gsr starters the same? Car won't start.
- Need help!!!!!
- Dumb question: Stroking B16a to 2 litre with OEM part
- bogging, hesitation, spuddering issue
- Gauge wiring help!!
- changing a type r Lsd into a Ls tranny?? PLEASE HELP!!
- exedy clutch stage 1
- 2004 Honda Civic LX MAP sensor wires.
- Using exhaust to vent carankcase?
- AEM EPM
- Code 15 ignition output signal
- brake pressure in front, no pressure in rear. Ideas? prop valve?
- jdm cable tranny compatibility
- 90 civic air compressor
- need help
- stock coil and msd cap ??
- B20 camshaft questions???
- Looking for a machinist (specifically align honing) advice and cam bearings
- R12A redtek freion. Has anyone used this stuff before?
- cable-hydro swap axel problems Sorry 56k
- Problems transferring tuned map to chip (Hondata S200)
- Crank seal blowing out!!!
- RPM gauge doesnt go past 6000 rpm
- 4g63 piston indentations (from valves) Opinions welcome!
- Quick question about sizing piston rings up for a rebuild...
- new key won't unlock doors/trunk
- N00b question - Clutch type torque wrench + extension
- customer car question
- Results: New gearspeed synchro rings on grinding tranny
- Wideband opinions
- idle problem, '99 b16a2
- need a wiring diagram!
- Can i pass emission with O2 simulator
- GSR 1-4 with LS 5th?
- GSR DRIVE CYCLE for OBD2
- need a shop in las vegas
- "MSD 6A" Ignition Hookup Question
- Bogging down under boost. . .need a diagnosis please!
- HELP please voltage problem thats driving me CrAzY!
- 92 Accord- Intermittent Cold Starting...
- Excessive smoke out the exhaust =(
- are the brake porportioning valves on disc/drum cars the same as disc/disc?
- Help me ID these Dizzys, dizzy, distributor, distributors
- gsr gears in a type r case??
- Any air conditioning techs?...
- Manual Stiffener Differences (B-series)
- Using higher octane fuel than recommended
- b16a tranny question
