View Full Version : Tech / Misc
- Clutch, Flywheel, and lightweight crank pulley
- LSD ????
- Whats wrong with my car.
- whats up with my cooling system?!
- How to make car more fuel efficient? How to increase mpg?
- weird soft brakes
- Koni /GC H22 spring rate IS it enough
- Cat converter size/length?? Will an Ek fit on my CRX???
- accord 4lug -SWAPPED- onto a EK civ... any gains?
- MSD Ignition box repair for street,race,car,truck
- need help identifying a part
- ITR LCA on an EK? HELP!!
- Going on to my second Clutch Master Cylinder, WTF??
- Are GSR and B16A valve seals same??
- weird knocking type sound and feel, please help.
- Flywheel bolt and torque question
- swap question b series eg hatch
- spring rates for skunk workz coilovers/help finding them out
- Anyone using NGK Plugs #PZFR6F11
- ***** Engine Break-In method POLL *****
- 01 Prelude SH or RSX Type S
- CEL checking on 1998 civic 4DR EX
- new clutch.. thrust bearing?
- mini-me + nitrous
- hondata minor change needed
- mini-me problems
- CRUNCHING FROM 2ND TO 3RD GEAR!!!!!!
- Running Open Header = Bad?
- LCAs: ITR vs DC/EG
- Tricky ? on Tein SS Coilovers (Broken Part)
- dx to zc problem in 89 hatch???? need major help??
- Just picked up used GSR head.. what to do when i go to machine shop.
- question about my ls-vtec
- VTEC Engagement Problem... Already searched...
- Needed: P05 OBDI ECU to DOHC VTEC HOW-To
- TRIAL USER?!?!?!?!?!??!
- Not enough ignition timing adjustment
- Y8 oil pump with A6 strainer, possible?
- couple of questions
- z10 vacuum pump system?? anyone use it?
- Best Test For In-Car Fuel Pump Function?
- If i run a p30 w/ the knock disconnected will it run bad??
- Ecu Pinouts
- how can I tell what b series cable tranny I just bought???
- car feels weird after stock cams put in....help
- LCA ?
- no vtec and revs to 5000 (b16)
- damaged caused by high piston speed
- How to tell LSD
- How to I identify a b18c SIR-G from a b18c type r?
- CTR Tranny!
- HELP Can't get into gear. Pressure Plate? Clutch..
- 92-96 prelude wheel hubs interchangable with accord?
- Re-bore cylinders
- valve adjustment concern
- Where to buy testing equipment (not online).
- Integra Shifter used with ITR Linkage, Si transmission in a 99 Civic DX
- B-series tranny questions
- Are my Tein NA's hosed? (pic)
- Main Relay Location (92-95 civic)
- How manny times can you resurface a billet aluminum flywheel?
- Help with airbag light
- Head work?
- accord 4cyl vs TSX
- Should I go with Accord Wagon or Legend 2 piston calipers?
- CEL 14 IACV, Im kinda lost
- Any one know the Stock ride Height for 1996 Honda Accord dx Sedan
- power steering ???
- Need a scan of how to do vavle adjustment !!!!!!!!!
- resurfacing pressure plate?
- should i change the evaporator if im chaning a A/C compressor?
- quick rotor $
- Is the heater core work with the a/c unit in any way?
- Need Help: LS Automatic to 5spd GSR
- knock detection tools/sensors for tuning
- Swapping cranks??????
- Dynoing questions
- impact gun & flywheel bolts, clutch bolts.
- GSR Gearbox & ITR Gearbox conversion..
- ¿¿can i put this in my transmission...??
- b20 in 90 teg please help with my ?'s
- gm synchromesh= penzoil synchromesh??
- Miss HItting help./
- Bumpstops
- ?'s on painting car
- Ek AC mail relay
- ignition problems.. cant get to 18 degrees... HELP??
- Question: B17a crank, B18a rods, and B16a pistons??
- what cams to run with this setup?
- Wiring a VAFC 2.....small question
- Turboing a Honda Civic EG 1.5L SOHC
- Tanabe exhaust owers
- N/A or TURBO?
- need ctr pistons asap
- ls vtec problem . help
- map sensors
- HELP! CEL after AEM fuel rail and fuel pressur regulator install
- question about suspensions
- in the middle of mpfi swap. cps?
- Fuel Pump won't start
- Anyone here use Omni-power Coilovers? vs. the Tein Flex type coilover?
- Odd brake problem
- Shift Rod removal. need help
- How do you check ur timing...? not change
- Spark plug wire order on distributer (Integra GSR)?
- gutted cat converter = more visible smoke at WOT?
- gar cam spec conflict
- o2 sensor on my gs-r
- bore and hone do I need to remove my main studs
- ls vtec POWER
- Ecu / Ecm list of ID #'s ****complete****
- Does anyone know?
- head work?
- bad noise in a 94 b18c1
- i need pics
- Master Cylinder replacement, bench bleed?
- weird harmonic sound
- ITR swap
- CX motor cranks, but wont start need help
- insulation/muffler question?
- cracked sleeve on block, how much would it cost to resleeve?
- Need help diagnosing problem with grandmothers car.
- what's a closed deck block? Open Deck?
- Wiring MSD 6A to replace the ICM (Ignition Control Module - Igniter)
- Brake Problem
- jdm itr tranny 4.785
- any oppinions on an A1 tranny?
- Switched 12v wire that stays on while cranking.
- 98 civic - SNAPPED STUD BOLT, HELP!!
- Sensors the p73 doesnt look for
- YS1 cable tranny on a JDM b16a?
- axle binding and wobble at high speeds...
- clevite bearings??????
- why do i keep blowing fuses?
- what ecu's are compatible for uberdata?
- help, my rear right shock smacks around and rattles after coilover install
- car still runnin hot,fan wont turn on!
- where can you get j's carbon fiber intake?
- some dude told me....
- Running metanol and gas
- any wheel alignment xperts out there?
- axle stuck in trani b18c1 HELP!
- great video link
- Best place to buy fab materials
- B18C bogging out around low RPM's. Need help please
- b16 block with ls crank
- Clunking/knocking noise under load...
- Need help!!!! car smoking
- Question about flywheel bolts-
- Kaaz & VSS????
- Tach installation help needed.
- Torque specs for D16Y7 lock nuts? valve lash
- Changing Valve Springs!! How to keep valves from dropping???(searched)
- problem with safc..please help!
- dead coils
- DPFI to MPFI Conversion Problem
- ACT Flywheel help??
- where does the A1 tranny come from...
- is ASAP motors legit....
- WTF dizzy issues?
- apexi catback
- Please help with compression test #'s and spark plug examination
- What is keeping this car from starting?
- Carbon cleaning out of header
- substitute for cleaning air filter (immediate help if possible)
- !!!!!!!!!!!B20z2 in a 97 Dx hatch Need HELP!!!!!!!!!!!!!!!!!!!!!
- quick question
- Do bigger injectors have the same sizes like stock injectors???
- no metal showing in the tranny oil, could I be locked out of my gears from my clutch?
- Ball joint question on 92 accord
- GSR Intake Mani Problem
- How do i use a valve spring compressor?
- Can you hurt the crank...
- motor throwing code 8, tdc position, how do i fix?
- Oil and RPM...?
- Sputter...??
- how to wire vx 5 wire into regular 4 wire 02 sensor?
- machine work prices.
- TWM ITB TPS QUESTIONs
- forum question
- EVAP Code Problems
- what are those long lugnut bolts called and who makes them?
- need help changing an auto to a 5spd!!
- surging idle after obd2-obd2 conversion.
- Question for the pin-out on a 92 CX motor
- itr cams....now there's a vibration
- TEMPLATE PLEASE HELP!!!
- DIY on Main Relay Check?
- ctr vs je high comp pistons
- 2000RPM.... at idle! 00' ITR
- Cel Code 6
- The Rare Disease on my B18c....
- changing brakes
- Wierd vibration noise from 7k to 7.5k on h22
- FUEL FILL PROBLEM????
- Piston to wall gap as well as ring gap...
- Please help me figure out whats wrong (B16A2 related probs.)
- lil help here, b16 problem.
- Valve seat size?
- Setting idle with a digital multimeter
- all b-series cam gears the same?
- Cam Journal Polish/Repair
- type r oil cooler
- make a diSoch Vs. Dohc
- B16 timing belt?
- VAFC II Intial Setup
- Piston removal
- WEIRD CEL!!!! 94 DX COUPE W/ 93 SOHC VTEC SWAP.....
- Help please - Engine drop from 4300 to 4k rpms
- Lug nuts? What can you tell me about them?
- Transmission or Clutch problen?
- Bad clutch or stripped gears?
- transmission swap: can i swap without removing the motor?
- type r engine swap
- need some info
- my radiator fan wont work, please help
- vafc2 trouble
- B20VTEC Compression check results...
- Is it normal for Momo steering wheels to spin loose?
- Light grayish with a tint of blue smoke coming out of the exhaust?
- guys help me!!!!!!
- "ROD BEARINGS"
- ACL bearing kits will it fit b20 eagle rods?
- ECU auto to manual conversion question.
- VAFC Question?
- air/fuel gauge install in an ef hatch
- Brake Booster Question... Having some Troubles, Need some Ideas
- SoCal or L.A...soldering ECU chip???where?
- Spark Problems.
- OBD1 chassis, ecu, harness.....OBD2 head, block....please help!
- 1.5L SOHC NA beast????????
- Amp lead shorted out, now car won't start!
- Quiefe LSD in b series making noises?????????????
- Flywheel dust cover
- need help on strut bars for civic
- tranny swap
- Stock B16 header off a 99-00 si same as b16 header off xsi integra?
- ecu question?
- Battery light
- A1, S1, Y1 and YS1
- gas seeping through fuel filter bolt.. need help.
- GUAGE CLUSTER problem
- Main and Rod bearings color codes???
- JDM B16A Skunk2 IM install help
- Will EK9 typeR LSD fit on EG6 with B16a2 engine?
- Help with Integra possibley the o2 sensor
- jimblake, Can you help?
- Stock Spring Rates
- ENGINE TECHS HERE: ENGINE HYDROLOCKED...NEED BLOCK...HELP ME PLZ!
- hp difference from the wheel to the crank
