View Full Version : Tech / Misc
- obd1 dohc zc
- Automatic Transmission experts: Your knowledge requested.
- burning oil at high rpm after using Seafoam. compression and leakdown fine
- 97 type R swap into 96 ek, now the car won't start(HELP)
- Custom Exhaust or Wait?
- (ECT) plug help
- best way to port match intake manifold.
- trouble with this swap
- b20 bloc + b17a head, timing belt?
- act pressure plate devloping surface rust from sitting while project gets underway what to do?
- Quick please how to diy air fuel gauge
- number 44 fuse keeps popping.
- help locating a dyno tuner searched like mad!!
- F22B1 & tranny performance
- squealing noise
- cel code 15 help pleeaaaasssseeee...
- valve lash on a b18b problems
- Project 70mpg city car?
- Suspension problems!!!!
- which air filter
- tranny question
- Cusco MC brace
- Heads+B16
- JGE valves springs for sohc
- ECU PINOUT Questions
- My exhaust problem
- CRX timing belt?
- how do you chip a p28
- dyno tuning
- D15B problems
- Crank angle sensor
- ??? GSR final drive in an LS tranny ???
- lsvtec & hondata
- difference between d16z6 and d16y8 pistons
- SeaFoam users got some questions for ya
- CAR WONT START!! need help PLZ
- CLUSTER CLOCK PROBLEM
- Has anyone installed a MSD ignition Setup??
- soft brakes, bled twice
- Trying to start car for the first time, crazy sounds and lights, WTF?!?
- Running peak & hold injectors without resistor box?
- help with vafc
- Air in upper and lower rad hose? HELP HELP!!!!
- Engine swap for 91 hatch
- How can we copy a computer chip???
- Tranny Fitment
- is my tranny blown?
- GSR water pump and timing belt on a B16
- Need a fix Car Show in ONE WEEK!
- exhaust question
- Ls/Vtec- What size ARP connecting rod bolts do i need?
- Ls/Vtec- Which Headgasket do i use?
- spark plug wires.
- its pissing me off!!!!
- ISB bad? need advice...
- Rattling issue
- help with ecu issue!!!!
- Ecu wiring
- Will cable clutch fit on hydro tranny??
- APEXi VAFC II VTEC controller.....
- replacing axle, but wont go back into the spindle...
- Brake Issues on EG
- CEL CODES LOOK HERE!!!!!!!!!!!
- Turning Car off at traffic lights to save on gas?
- 98 civic LX wire harness to a jdm b16 motor
- HELP!!! Engine throwing a o2 sensor code???
- help car stop while driving then car wont start again cel code 15 on obd 1 ecu
- Hondata Questions
- 2000 Civic Climate/radio bezel in Acura 1.6 EL
- Small scratches in main journal
- Anyone here a tech at honda? I need some info validated
- code 6 and 20?
- b16 + turbo
- gsr to si-r
- Hazard module
- my vtec dissapared
- your honest opinion of my engine set up.....potential?
- 4.4 civic ex FD
- skunk2 Stage 2
- Frankenstien. Twin turbo?
- T25 + B16A2 ?
- Distributor doesnt go in
- Reverse lights f@*ked
- hesitation problem
- AHHHH FUEL LEAK!!!!
- How to hookup gsr secondaries to ls block?
- vtec turns on off
- Clutch Springs and engine "movement"
- P72 in JDM H22A
- obd1 ls auto parts work on my obd1 b16
- Is this the vehicle speed sensor going bad?
- OEM paint job so cal
- Installing traction bar...alignment? searched...
- Cable Tranny Problem, HELP
- ****CRX wont fire up ANY HELP IS APPRECIATED*****
- how to check if trans is stolen?????
- CEL problem..help..
- OBX Diff clearance question.
- HELP ALL GURU"S!!!
- Doesnt fit - replacing ACT with... ACT !!!
- b18b rebuild...
- Best bearings for boosted d16
- Threded plugs in crankshaft
- B16a motor problem...any ideas?
- What kit would be used to rebuild a automatic tranny from a JDM B16A?
- Shifting Problems. Any ideas?
- Please recommend a good and honest mechanic in L.A. area
- How do you replace the Cam seal (plug)?
- what year integra clutch for a B16 cable tranny
- sometimes clutch engages way to early when letting off the pedal
- Air fuel Gauge into 92 civic.... wut pin on the ECU is it??
- ITB air box
- HowTo: DIY Exhaust Coating
- changing a Auto p28 to a Maual
- test pipes
- ehxaust leak?? hissing sound.
- Difference in b series oil pans
- LEAK!! Waterpump Center Area - Where could it be coming from???
- SAFC2 Help PLEASE
- B16 Axles
- loud hissing sound comming from car (turbo'd)
- Looking for a new muffler, need advice
- need help on lsvtec
- rywire tunes?
- Having trouble shifting.
- gsr mani help
- Where to Buy or Download Crome Pro
- Weapon r intake Good? Bad?
- looking for a thinner head gasket
- little question...
- Good Steering Wheel Hub?
- Alkaline/acid dipping
- WHO MAKES "SS" Intake and exhaust manifold bolts.
- Please help me, oil in 4 :(
- D16y7 injectors on a B18b1?
- Information on the VX, HX, vtec-e, engines please?
- ls to gsr
- Eliminating Banjo bolts in the fuel system ... how do you do it?
- Pedal Stopper?
- blown engine ?s
- Code 71- Cylinder #1 misfire
- Piston and Rod Install Honing?
- got a question about ross pistons
- Need Help Wiring Fogs
- RHD conversion tech thread
- engine removal?
- 99 si wiring
- stainless valves
- Warm Car = No Start!
- Question about valvetrain
- dashpot connection question......
- opinion all motor or boost
- RESONATOR QUESTION!
- B18C JRSC Engine Sputtering / Choking When Driving
- d16z6 valve adjustment and now surging/hesitating while driving
- Gas Saving Pill ! WTF?
- Research on: JG 301 camshafts
- SRS help please!
- Starter relay on 94 Integra??
- bosch 3737 o2 sensor
- Crank Concern......
- Whats wrong with my clutch???????????????
- i need some help PLEASE!!!!!!!!!!!!!!
- ***How-To*** Install Valve Springs & Valve Stem Seals
- obd...1...2...blah,blah,blah
- Honda Type-R engine problem
- Please help.
- what bearing to use in a GSR block w/LS Crank
- loud knock from the head
- CBR-MPFI-DPFI TPS compatibility
- can electrical vss be interchangeable with mechanical vss?
- the raised hood thingy
- quick E-manage question
- H22 into Crx with Hasports, just a few questions.
- help solve this idle problem (searched)
- Rear toe adjustment?
- LS Crank and Pistons in B16 block?
- Starter cable assy. caught on fire?? WTH!
- Oil pickup to pan clearance
- What causes this?? Bearing Carnage
- Syncro Replacement
- d16z6 bottom end with d16y7 head
- 90-93 Teg Half-Shaft on OBD0 B16A1 and Hydro tranny My observation just to clear some things up.
- 97 ITR JDM engine harness question!
- Wastegate & Injectors Question
- B-Series VTEC exhaust cams
- What bearings would you use
- 91 ls/gc ecu 95 d16z6 in 89std
- takin out emissons need help blockin off
- Modified OEM 3 layer headgasket
- Ge or Arp Head studs
- blocking oil jets??
- Will a intake manifold for Del Sol B16A work on a 00 Civic B16A2
- i need an inspection sticker...MA area
- Will this be a problem???
- how to...change cams
- speedometer problem
- Engine cranks won't start
- HELP
- Light weight flywheel question's. What are you guys using?
- FIRING ORDER
- Bad Idle Now Car does not run AT ALL!
- b16 vs gsr vs itr tranny gear ratios
- New fuel gaugeDoes autometer make a fuel level gague that will work with the stock sending unit?
- 00 si cel
- 40 amp Igntion fuse keeps blowing?????
- Damn defi tach wont work
- s2000 Cluster in any car!
- synthetic vs. non-synthetic
- 95 eg6 headlights dont work but the corners get power???
- where to buy?????
- p28 question
- oil filter change - dented the filter, is it okay?
- pcv problem mini me dont kno were it go's? help
- lights not working
- Affordable and Reliable Insurance Services!
- Bearings, Oversize/Undersize?
- help need to kno on pistons!!
- low pitch whiring noise, CV's?
- d15b swap, engine wont start. help!!!!
- need help on valve timing!!!!
- need help replacing inner tie rod...
- EF/CRX forum did not help. Maybe you can....
- HELP!!! EF WIRING HELP!!! ASAP!
- clutch...
- d16a1 head/camshafts
- Anyone ported a nonvtec b20 P8R head yet?
- Tranny spline question - how much play should there be?
- speed sensor problems plz help
- we are proud to show you the most complete honda engine spec list
- can someone please send me a link for the crome tuning software
- temp sensors.... anyone know where to buy them
- "check engine" yellow mark indicator
- ***17in UniverSal 4Lug Rims***Need them gone ASAP
- will a 99-00 civic si p2t ecu work in my 99 gsr
- D16Z6 VTEC problem.
- obd2 -> obd1 p72 problem
- Bouncing Idle While Warming Up
- B16A2 clutch same as B16 cable clutch?
- CEL Light and other weird engine questions....
- turbo kit
- rattle clacking noise help?
- quick question....
- crower billet d series rods torque spec?
- #1 Racing Parts
- Need help after o-ringing block should i ......
- Torque for bolt of crank pully B16A2
- car wont start....thing i bent some valves...check this out
- Automatic to Manual Conversion?
- VAFC2 install into a b16 help please can't get instructions from apexi????
