HELP Code 54 crank speed fluctuation ?????????
Old Dec 15, 2002 | 02:48 PM
StageIIIhb98's Avatar
Default HELP Code 54 crank speed fluctuation ?????????
Don't flame me for posting this in another section But I Need Help.
I have a Turbo system on a stroked b16 OBDII with factory ecu. I have the timing set to stock. I have also retarded it and the code came back Any Idea what could be causeing this could
By the way when I start to boost sometimes it takes off right and sometimes it bogs out to the point where i have to keep taping the piddle to get it to rev right.
I don't know if it something to do with the code but I hope some of you out their can help me find out thanks.
Old Dec 15, 2002 | 04:32 PM
3rdGteg's Avatar
Default Re: HELP Code 54 crank speed fluctuation ????????? (StageIIIhb98)
check the ckf sensor circuit mounted on your oil pump. From my recent experience with obd2 motor without the ckf sensor, it does that. I just installed a motor w/o the ckf sensor and it sometimes take off fine, then others it seems to lag and stutter. If u got ur's on, check to make sure it's working properly.
Also is ur idle above 1000rpm? Mine is and I'm trying to figure out if that sensor could also be the cause.
97honda_accord
Apr 11, 2015 08:29 AM
471r
Feb 18, 2015 12:43 PM
darksolguy
Jul 15, 2008 10:59 PM
jessej
Mar 30, 2005 05:39 AM
mraudio13
Sep 19, 2002 05:34 PM
