Need help...
Old Dec 18, 2002 | 07:01 PM
87sivtec's Avatar
Default Need help...
I will give the run down. I have an 87 crx si (first gen) with a second gen B16 in it. I am running the engine with a PR3 ecu and first gen B16 dizzy. I have the high impedence injectors and so have removed the resistor box. My problem is that I am running extremely rich. I have two new O2 sensors and I am not getting any error codes. At idle my air/fuel is right in the middle and as soon as I hit the gas pedal, it goes full rich. Can anybody help me?
Old Dec 18, 2002 | 07:38 PM
tominos's Avatar
Default Re: Need help... (87sivtec)
u could get a fpr and turn down the fuel pressure a bit.
Old Dec 18, 2002 | 07:59 PM
87sivtec's Avatar
Default Re: Need help... (tominos)
See that's the thing. I am running only 31 psi when the engine is running. I forgot to mention that in the first post.
I am going to pull the fuel rail and injectors this weekend and make sure the spray patterns are good and also double check all the ecu connections just to make sure I haven't missed anything.
Old Dec 19, 2002 | 02:55 PM
87sivtec's Avatar
Is anyone there? I could really use some input. Thanks.
Old Dec 21, 2002 | 11:04 PM
87sivtec's Avatar
ttt
Old Dec 22, 2002 | 09:06 AM
tnbigdawg's Avatar
I think that is why you should run the resistor box to tune down the injectors.
Old Dec 25, 2002 | 10:27 PM
87sivtec's Avatar
Default Re: Need help... (tnbigdawg)
They are high impedence injectors and they wont fire with the resistor box.
Since my last post I have pulled the fuel rail and injectors to check for leakage and the spray pattern. Everything is very clean and working flawlessly.
The second gen B16 came with injectors that do not require the resistor box. They have the proper impedence without it.
I have checked their impedence also, just to be sure that they are within spec.
Do you think that the MAP sensor could cause anything like this?
Running out of ideas here. I may just buy a VAFC and tune it down.
I would rather not put a bandaid on the problem without first exhausting all alternatives.
Old Dec 25, 2002 | 10:45 PM
AussieK24's Avatar
Can't help you, sorry..... This is the reason I went to aftermarket EFI. Got sick of trying to please the f#$%ing factory computer
Old Dec 26, 2002 | 09:42 AM
87sivtec's Avatar
Default Re: Need help... (b16a4me)
No kidding!
Kenzo206
Apr 24, 2009 02:59 PM
La EF-8
Jul 30, 2006 06:09 PM
wsriane
17
Jul 29, 2006 01:59 PM
onesikcivic
Jun 19, 2005 04:25 PM
barry11j
12
Sep 29, 2004 08:47 PM
