idle too damn high...
Old Dec 19, 2002 | 09:26 AM
B_CRUZ!'s Avatar
Default idle too damn high...
I have checked for leaks in between the t/b and the manifold, the manifold and the head. I have adjusted the TPS, Cleaned the IACV, replaced all of my vacuum lines and changed the PCV valve. I adjusted the throttle return stopper, loosened the throttle cable.
Why the hell is my idle at 1100rpm?
stock gs-r motor with a stock manifold, 9.5 flywheel and stock p72. All OBD1.
Please help me
Old Dec 19, 2002 | 09:29 AM
Desslok's Avatar
Default Re: idle too damn high... (B_Cruz)
flywheel
Old Dec 19, 2002 | 01:16 PM
Jeff C's Avatar
Default Re: idle too damn high... (sp)
flywheel
What do you mean?
Do you have an idle adjustment screw on top of the throttle body?
Old Dec 19, 2002 | 01:31 PM
B_CRUZ!'s Avatar
Default Re: idle too damn high... (Jeff C)
yes and that is all the way tight...
Old Dec 19, 2002 | 01:34 PM
Desslok's Avatar
Does it go down when you unplug the IACV? The flywheel will cause higher idle.
Old Dec 19, 2002 | 01:37 PM
B_CRUZ!'s Avatar
yes the idle goes down when it is uplugged but not by much.... i do get a cel real quick though when i unplug.
[Modified by B_Cruz, 2:37 PM 12/19/2002]
Old Dec 19, 2002 | 02:07 PM
dr650's Avatar
New User
CHECK UR SECONDARY BUTTERFLY FOR LEAKS OR VALVE ADJUSTMENT!!
LATER
FOR SALE!!!
bay area only<<<pick-up only<<i got this following stuff for sale:
92 ls motor /trany/ecu for $600 (rebuild motor trany no grinds)
93 prelude motor/trany/ecu for $1000(h23)(motor has 148000 mlz/trany no grind/still good compresion/needs water pump)
95 si trany for $200(no grinds)
92 ys1 trany for $400(da gsr)no grinds
92 integra trany for $200(no grinds)
94 si motor for $250(100000+ mlz)needs head gasket
pwo ecu for $100
cr/vtec motor for $1600. still in the car.no leaks.(b16 head /jdm b20z)
91 integra ls for sale >>$2500 210000+mls.
Old Dec 19, 2002 | 02:12 PM
B_CRUZ!'s Avatar
Default Re: idle too damn high... (dr650)
i just got a valve adjustment done by the Acura dealership a month ago and i doused all of my secondary vacuum ends with carb cleaner. i also changed all of my vacuum hoses.
Old Dec 19, 2002 | 02:56 PM
gtpilot's Avatar
How is your water temperature? I have had a bad thermostat that caused the motor to run cold - the Temp Sensor told the ECU it was cold and the Idle Mxiture was enriched and made it idle fast...even after driving ti for 30 minutes (sometimes as high as 200 RPM). I put a new thermostat in it at it immediately came back to normal.
Kirk
Old Dec 19, 2002 | 03:02 PM
B_CRUZ!'s Avatar
Default Re: idle too damn high... (gtpilot)
temp guage reads normal. i replaced the thermostat right before the swap... thanks for your insight though...
keep them coming people....
Old Dec 19, 2002 | 03:58 PM
Desslok's Avatar
Timing?
freddy chavez
Apr 8, 2013 07:40 AM
protopro88
Apr 8, 2011 03:41 PM
IntegraType-R
11
Jan 20, 2008 11:23 PM
crxdriver1991
Sep 22, 2006 01:25 PM
B_CRUZ!
15
Dec 19, 2002 02:33 PM
