redline drop
Old Dec 17, 2002 | 05:01 AM
one pnt 6 hatch's Avatar
Default redline drop
I have a 89 civic hatchback with a 90 integra Ls motor its loses all its power at 5200 but it use to hit around 6500. would that have to do with my screwed up timing or what?????!!
Old Dec 17, 2002 | 06:15 AM
Spade's Avatar
Default Re: redline drop (one pnt 8 hatch)
Or your O2 sensor or your spark plugs or you need to change the oil or you need to replace the rings or ..........
Do you burn oil?
Have you done a compression test?
Old Dec 17, 2002 | 02:35 PM
Default Re: redline drop (Spade)
dont burn oil, runnin really rich, timin belt real loose, havnt tested it yet for compression or leak down or any of those good test yet. bout to change oil in the next couple of days. spark plugs are brand new and gapped. and throwin a code 43 on the ecu. it deals with the fuel suply system. i have the new timin belt and all the things i need to fix it but cant get the crank bolt off.
AudioFunk
Apr 16, 2014 09:24 PM
x_40oz
Dec 16, 2013 07:24 AM
Superinteg
Oct 13, 2010 03:00 PM
Ej2-93dxer
May 12, 2010 02:36 PM
Layziebtnh055
May 12, 2004 07:05 AM
