-AN fitting size (fuel lines)
Old Dec 17, 2002 | 06:56 PM
D0HC's Avatar
Default -AN fitting size (fuel lines)
I am looking to run stainless fuel lines and wanted to know what size adapter I could use from the fuel filter to the fuel rail etc etc.? I am guessing it would be a 6 AN fitting which I think is 3/8" but would they take a standard fitting? I am guessing it would be metric. b16a2 and the line it self will be 3/8.
Any ideas would be appreciated.
Old Dec 18, 2002 | 01:51 PM
upstatecrx's Avatar
Default Re: -AN fitting size (D0HC)
bump i would like to know too
Old Dec 18, 2002 | 01:56 PM
VTEC4GS's Avatar
hello, its a metric thread 12mm x 1.25mm ... you can get the aeroquip banjo fittings and it'll work, Unless you're planning on going past 100psi fuel pressure its a waste of money and time IMO ...
Greg
Old Dec 18, 2002 | 08:00 PM
D0HC's Avatar
Default Re: -AN fitting size (All Motor CHEETAH)
Thank you. Is that thread size used for both the fuel filter and rail. If you know of any of the other sizes for the fuel system let me know. Thanks again.
Old Dec 19, 2002 | 12:00 AM
brian b's Avatar
New User
http://www.anplumbing.com
991945 fits into your filter and has a -6 end
you need a -6 90 degree fitting (or a straight fitting and a 90 degree bend)
some hose
-6 hose end
991945 fits your fuel rail
Old Dec 19, 2002 | 01:23 PM
D0HC's Avatar
Default Re: -AN fitting size (brian b)
Thanks for the great info.
jksmith
Oct 4, 2011 03:53 AM
eg:R
Mar 5, 2010 05:00 PM
atlplayer4life90
Sep 2, 2009 04:30 PM
Lyrikz
Sep 17, 2003 07:27 AM
senpai
Jul 20, 2003 09:40 AM
