DIY header collector - how's it look?
Old Dec 15, 2002 | 07:57 PM
94gsr's Avatar
Default DIY header collector - opinions?
http://www.imagestation.com/mypictur...&id=4243430047
I got some mandrel "U"-bends from JCWhitney and did a shitload of cutting, welding & grinding to get what you see. It's obviously not a show-piece, but I'm not worried about it being pretty - except for on the inside where the pipes merge. That's the one spot where it actually IS pretty, but I didn't get the pics uploaded yet.
[Modified by 94gsr, 9:07 PM 12/15/2002]
Old Dec 15, 2002 | 08:28 PM
B19CivicHB's Avatar
Default Re: DIY header collector - opinions? (94gsr)
Looks nice. Welds are a bit rough, but function over fasion right?
Are the welds smooth on the inside? If they are rough like on the outside, id try to find a way to smooth them down.
Looks nice though.
How long did it take? How much did it cost?
-Nick-
Old Dec 15, 2002 | 08:30 PM
B19CivicHB's Avatar
Default Re: DIY header collector - opinions? (B19CivicHB)
Oh and here's the pic for all you lazy fellas
-Nick-
Old Dec 15, 2002 | 08:31 PM
EKhatch's Avatar
Well it LOOKS pretty good. I hope it gets good results, it looks like you spent quite a bit of time on it. I don't know much about exhaust flow but it looks a little long? Any reason for this..... torque?
Old Dec 15, 2002 | 11:15 PM
Nameless RB26's Avatar
Default Re: DIY header collector - opinions? (EKhatch)
..what is that thing? I can't identify it without a complete pic.
I'm guessing it's the end of a header?
Old Dec 16, 2002 | 12:24 AM
Honda F1's Avatar
Default Re: DIY header collector - opinions? (Nameless)
Nice DIY job! Looks kind of like a poor man's Hytech header.
Old Dec 16, 2002 | 05:58 AM
94gsr's Avatar
Default Re: DIY header collector - opinions? (Honda F1)
My welding skills have pretty much been self-taught & I've only got about ten hours of experience, but they're getting better.
The length is to help broaden the torque curve & produce more torque before the peak.
Total cost, excluding gas & wire for the welder, was about $25 for the piping. Total time involved was probably around twelve hours at the most.
The insides of the welds & the merges are as smooth as a baby's ***.
[Modified by 94gsr, 7:42 AM 12/16/2002]
Old Dec 16, 2002 | 06:40 AM
vntperformance's Avatar
what size is the collector buddie?
vnt
Old Dec 16, 2002 | 06:43 AM
94gsr's Avatar
Default Re: DIY header collector - opinions? (vntperformance)
Exit is 2.5".
Old Dec 16, 2002 | 07:56 AM
B19CivicHB's Avatar
Post up more pics
-Nick-
Old Dec 16, 2002 | 10:10 AM
94gsr's Avatar
http://www.imagestation.com/mypictur...20other%20side
[Modified by 94gsr, 11:11 AM 12/16/2002]
Old Dec 26, 2002 | 12:54 AM
project dc2's Avatar
how long it take you to do that ?? and how'd you figure out angles and how big and whewre to cut etcc ? im tryin to do my own merge collector etcc.
Old Dec 26, 2002 | 03:46 AM
Mista Bone's Avatar
D Tranny Guru
and to think you could have bought a Flowmaster Pulsetech collector and be done!!!!!
Old Dec 26, 2002 | 06:09 AM
ImportechPerformance's Avatar
Default Re: DIY header collector - opinions? (Mista Bone)
ohhh Mista Bone that looks very intresting.... got any more info 0n that lil piece?
Old Dec 26, 2002 | 07:30 AM
owen_the_soyboy's Avatar
MisatBone, WTF is that!!?>!?!?!??!?!
wowsers!
Old Dec 26, 2002 | 08:18 AM
kb58's Avatar
Banned
What are the specs? Primary lengths, diameters, secondary lengths, diameters. What rpm is it tuned for? How did you chose your design specs?
Old Dec 26, 2002 | 10:37 AM
Austin's Avatar
Your 4-2-1 merge looks an aweful like the HyTech merge...looks like a copy...
Old Dec 26, 2002 | 11:06 AM
Snapshift's Avatar
Dude NICE job! looks tight. I andmire people who build there own performance. Versus catalog shopping
Old Dec 26, 2002 | 07:38 PM
94gsr's Avatar
Default Re: DIY header collector - opinions? (Snapshift)
The JDM ITR headers have offset primaries. So that box collector with the "too-short-for-what-I'm-looking-for-anyway" secondaries, would not work for me even if it would actually fit on the header.
And what exactly do you mean by "copy"? Hy-Tech makes their headers a certain way for certain reasons. To accomplish what I was looking for, I needed longer primaries & long secondaries, whether or not someone manufactures something of a similar design or not. Not to mention the fact that I used my own experimental specs.
It only took me probably about 12 hours total, for all the work.
As for the angles, turbulence is created when flowing air is forced to bend at more than a 10° angle. I just cut pieces out of U-bends to get near that 10° for minimal turbulence & welded things up. It's really a trial-and-error type thing. You just have to start into it & "feel" your way through. The cuts are all straight cuts, nothing complicated there, you just have to make sure that your cut is actually straight, and that things line up properly. If you would like me to help you with your collector, just IM me.
[Modified by 94gsr, 8:40 PM 12/26/2002]
Old Dec 27, 2002 | 01:59 AM
Mista Bone's Avatar
D Tranny Guru
Congrats on the work, your atleast ahead of me! I've yet to learn the welding/cutting aspect, but know what I want.
BTW, Hy-Tech was not the first to use the 4-2-1 merge style they use. So don't feel bad if everyone thinks it is a copy.
John @ Hy-Tech and Dave @ SMSP both stirred my brain with ideas. If I make a header to what I want, will everyone think it is a copy? Or I can send the specs to either builder and have them do it.
One, I don't have the money.
Two, mine would be a ugly duckling compared to the quality both shops turn out.
Three, creating/building you "masterpiece" is the greatest teaching tool there is.
Ever think what the salt lakesters went through when they needed something?
They built it themselves. Some failed, BADLY! Some did ok, some learned, and some improved, trying again.
Vic Edelbrock Sr. ring a bell? They didn't have the nice computers back then to figure flow ratings and other whatnots. They went with gut instincts. Some worked, alot failed. Learn from your mistakes.
ALWAYS LEARNING!
Old Dec 27, 2002 | 09:49 AM
kb58's Avatar
Banned
No offense to the fab, but what about the design? The fact that it was made doesn't mean anything if it's based on no data which is proven to work.
I keeps seeing this sort of thing here, someone makes a header and everyone congratulates them on a nice looking part, like that's the end of it. What's the point of making one unless:
1. You had to make one to fit a special setup.
2. You need a header tuned to a "non-standard" rpm range.
3. You have a new design which is better then anything out there.
4. You can make yourself it cheaper than buying one.
Which one does this header fit?
It just reminds me of someone taking great care to make square pistons. Nice workmanship perhaps, but what's the point?
Old Dec 27, 2002 | 10:05 AM
Austin's Avatar
ALWAYS LEARNING!
You know...I was trying to be nice by simply saying that it looked like the HyTech...I was not "bashing" or "slamming" someone for it, simply said that it looks like it's a copy of the design that HyTech uses...could you please direct me to someone else that was using the long tube primary design on a 4-2-1 before HyTech, as I have yet to see it. The only people that I have seen use the longer primary was HyTech, SMSP(after HyTech), and the new Comptech(which is an almost exact copy of my HyTech). If you know what you want from a header, that's nice, where did you get your ideas? If you take an idea from someone else, I do believe that it is a form of copying...
Austin - who was trying to be nice
Make your own decision:
Old Dec 27, 2002 | 10:57 AM
94gsr's Avatar
Default Re: DIY header collector - opinions? (kb58)
kb58:
1. The stock collector for the ITR header is garbage IMO, and I wanted a tri-y with long secondaries to improve low-rpm performance. So this did need to be made special.
2. If you make your own collector, you can tune the header to whatever rpm range you desire - a "standard rpm range" doesn't cut it for me if there's more power to be had from tuning to a different rpm range, (as there usually is). If you don't like the outcome, you can make another one to different specs for a different rpm range.
3. The design is not new, but current, or even old designs can be manipulated to indeed be "better than anything out there".
4. You would be lucky to purchase a long tri-y collector like this for less than $500. Total cost for me was under $50, taking into account the gas & wire for welding & the bits for grinding & cutting.
The ultimate point is to manipulate your torque curve and realize the full potential of the header, in whatever the desired rpm range is.
Austin:
Point taken. I saw the Hy-Tech piece when the original pics were first posted by John quite some time ago, and it piqued my curiosity. The design was new to me so I started researching & asking questions about it - i.e., why the long primaries, and the long & seemingly small secondaries. The knowledge that I acquired about exhaust flow through a conduit, (many thanks to Dave & M.D.!), led me to make what you see. I definitely would not claim the design, or idea for the design, to be my own. However, the specs are my own, as I have no idea what specs are used for any other headers.
[Modified by 94gsr, 11:58 AM 12/27/2002]
Old Dec 27, 2002 | 02:29 PM
Mista Bone's Avatar
D Tranny Guru
Default Re: DIY header collector - opinions? (Austin)
Austin, think outside of Hondas. Research Tri-Y headers for V8's, been around a long time.
Old Dec 28, 2002 | 10:42 AM
kb58's Avatar
Banned
That's cool. I was just wondering if you knew where you were going with it, and had done your research. I realized my post could have gone across as harsh but thanks for the polite explanation.
