how the hell do you remove the brake hose bracket off stock struts???
like the title says. i'm in the middle of my tein ss installation...i've tried hammers, screwdrivers, chisel, you name it
... someone gots to have the answer. it will be greatly appreciated
David
David
Might be welded on. In that case, you will have to break through the weld. Dremel works well. mine werent welded but i dd use a small sledgehammer (15lb) for persuasion.
If you need the brake line braket for the Tiens then I hope you are replacing the stock struts or at least have them laying around in your garage.
If the struts you are replacing have welded brakets, don't bother they are not the correct ones. You have to use the oem brakets. OEM brakets can be tapped off of the oem strut with a hammer and tapped onto the Tiens, Koni's, etc.
What car are you installing on?
[Modified by SLPR, 6:12 AM 12/20/2002]
With a hammer and a large, flat blade screw driver in the case of my Civic. Its just press fit on there.
Mike
Mike
Good luck, let us know how it turns out...
**maybe try some PB Blaster, it could help free up the brakets??**
[Modified by SLPR, 9:00 PM 12/23/2002]
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote »</TD></TR><TR><TD CLASS="quote">i'm installing the new 90-93 DA integra ss coilovers and yes i am trying to remove the brake hose brackets of my STOCK oem struts. the brackets don't wanna seem to budge. maybe a big *** mullet...oops, i mean mallet will do the job</TD></TR></TABLE>
Please do not use "mullet" and "Integra" in the same sentence or even discussion for that matter
Modified by lightning at 1:54 PM 8/26/2003
All you really need is a securely mounted table clamp and a 5lb sledgehammer. Put the shock in, rest the collar on the clamp, and smote it through. Takes 20 seconds.
Edit: Hehe. That "b.e.a.t" = "smote" thing in effect.
[Modified by IN VTEC, 11:09 AM 12/26/2002]
I'm having the same problem right now. Came in to check if anyone else had the same problem. Well, back outside I go to bang some more with the hammer and this time with a chissel helping. Mine looks to be welded, but I hope I am wrong.
BTW >> Tein SS as well
Zion-I
Suspension & Brakes
Jan 19, 2006 06:32 PM
SiB16A
Suspension & Brakes
16
Jul 19, 2005 11:10 AM
