Intake Manifold trivia
Old Dec 16, 2002 | 06:03 PM
SpoonMan's Avatar
Default Intake Manifold trivia
Does anyone know if a B18C1 GSR (2-piece) Intake manifold will fit on a B16A II engine?
thanks
Old Dec 16, 2002 | 06:11 PM
brian b's Avatar
New User
Default Re: Intake Manifold trivia (SpoonMan)
no
Old Dec 16, 2002 | 06:21 PM
Shawn C's Avatar
In The Garage
Default Re: Intake Manifold trivia (brian b)
no the gsr has different intake ports than any other engine. an integra type-r intake manifold would work, though. besides, you would lose power with a gsr im anyways. the secondary butterfly valve design is tuned for a B18C1
Old Dec 16, 2002 | 06:26 PM
Shawn C's Avatar
In The Garage
Default Re: Intake Manifold trivia (22lbGS-R)
just so you know... intake ports --> B18A/B (LS) & B20B/Z (CRV) same, B16A (Si) & B18C5 (ITR) same, B18C1 (GS-R) different
Old Dec 18, 2002 | 05:41 PM
StorminMatt's Avatar
Not quite. B18A intake ports are smaller than B18B/B20 intake ports. But the manifold bolt patterns are the same. So you can interchange intake manifolds. But this could hurt flow. Especially if a B18B/B20 intake manifold is used on a B18A.
Old Dec 18, 2002 | 06:40 PM
Kataku2K3's Avatar
Default Re: Intake Manifold trivia (StorminMatt)
It can be done but requires modifications... You can modify the manifold itself to bolt to the PR3 head, or look into a conversion plate as Erick's Racing runs... Latez
SpoonMan
Dec 16, 2002 08:54 PM
