Swap from p3k to phk pistons
Old Dec 20, 2002 | 01:05 AM
Norcalstoppy's Avatar
Default Swap from p3k to phk pistons
Do I have to hone the cylinders? or could I just put them in since they're stock? I want those for slightly higher compression and so that I could make the valve relief on them bigger for messing with cam gears.
Jay Kim
Old Dec 20, 2002 | 10:30 AM
Default Re: Swap from p3k to phk pistons (AllMotorMonster+)
come on now....i know you know!
Jay Kim
Old Dec 20, 2002 | 10:37 AM
Kataku2K3's Avatar
I would atleast hone the block... If you got new pistons and rings definately do it... I personally won't even do that unless the cylinder walls are really clean... I would just overbore .25mm and go with oversized PHK pistons... I guess that doesn't really work if you already have them but i would atleast get the block honed.. Good Luck
Old Dec 20, 2002 | 08:45 PM
Default Re: Swap from p3k to phk pistons (JDMspecEG6)
can you hone the block with out taking it out of the car?
jay kim
Old Dec 20, 2002 | 09:13 PM
Kataku2K3's Avatar
Well it depends on if you do it yourself with a bottle hone or send it into the machine shop.... I would just pull it and totally disassemble you block, and have a machine shop do it.... Then when you put it back together you can Mic and Plastigauge all the journals... Latez...
Old Dec 22, 2002 | 01:41 AM
tinkerbell's Avatar
jay kim
flashback - 8000rpm redline for B20VTEC safe?
the question was asked, now you want to cut corners?!?!
do it right the 1st time and you wont have to do it again.
yes, you can do it in hte car, but mistakes will multiply and inaccuracy will reign supreme
it is HARD, unless you have done it a few time before, or you could practice on an old block before you tackle the expensive one.
anyways, not really helping am i?
patience, is the key to reliability
t..
Old Dec 22, 2002 | 06:10 PM
Default Re: Swap from p3k to phk pistons (tinkerbell)
yes yes yes..i know.
But i found a good deal on a used phk pistons and wanted to see if I could just swap it out.
Jay Kim
Old Dec 22, 2002 | 06:35 PM
No-Gi's Avatar
It can be honed with the engine in the car BUT, It will not be perfect. I have done this many times and after putting the motor back together I have noticed a lot of oil comsumption. Also, From my understanding B20 Cylinders after a while are out of round. ( ClubSI, GOD) so you may not get a good seal on those pistons.
BTW I dont think they made overbore pistons for the b20.
Old Dec 22, 2002 | 08:00 PM
JCushing's Avatar
Default Re: Swap from p3k to phk pistons (3 South)
they make the standard honda .25 over pistons
avalible from http://www.hondaautomotiveparts.com for 126 for the pistons (4) and 91 for a set of rings
basically 200 bux for a brand new set not bad eh?
Old Dec 24, 2002 | 04:41 PM
tinkerbell's Avatar
Default Re: Swap from p3k to phk pistons (JCushing)
hows this?!?!
speaking with a b20vtec guy in Malaysia,
*apparantly* his motor builder used Ford TX3 pistons in his block = 11.1 CR.
dunno how true, waiting on the response, but hey who knows?!?!
ill get back to here shortly...
t..
Old Dec 24, 2002 | 04:45 PM
tinkerbell's Avatar
Jay Kim
how old are the pistons (miles)?
im pretty sure you should repalce the rings, so a slight hone is necessary, (do you have an old block to practice on?)
(these pistons would be good for a few compression points , better than milling hte head like me )
good luck.
t..
Old Dec 24, 2002 | 04:54 PM
good luck.
t..
The guys said the pistons have 15k miles on them, but the rings are new. It's a left over from his build-up. He decided to go with aftermarket pistons. It already has the enlarged valve reliefs for the vtec valves(for advancing cam timing up to 4 degrees).
Well, I decided to just save the money and resleeve my block later when I blow it.
Jay Kim
Old Dec 24, 2002 | 07:47 PM
JCushing's Avatar
youve got my attention man... as far as im concerned a piston is a piston and Considering 10:1 was the best you could do on oem honda 11:1 sounds alot better!!
Old Dec 25, 2002 | 04:33 PM
tinkerbell's Avatar
yep! smae here!!!
ill let you know...
t..
Ryhaz
10
Jan 14, 2014 07:57 AM
BokChoy
Sep 10, 2005 08:59 PM
Tropicana18T
Feb 23, 2004 03:40 PM
G_Man604
Dec 2, 2003 10:16 AM
gtcali
Jun 14, 2002 03:49 AM
