ITR head on B16
Old Dec 18, 2002 | 11:23 AM
Nos4R2's Avatar
Default ITR head on B16
i know that the ITR head and B16 head are almost the same but i would like to know if the ITR head will be a 'simple' bolt-on for the B16 block? meaning that it would be like you bolted-in a B16 head without having to change any parts at all like distributor, injectors, pistons, etc. and it would work?
Old Dec 18, 2002 | 11:58 AM
lsvtecracer's Avatar
Default Re: ITR head on B16 (Nos4R2)
the itr head will bolt right up with no mod needed to the b16 block...if your car is obd1 then you'll have to change out the injectors and dist...
Old Dec 18, 2002 | 04:18 PM
dohcsideSi's Avatar
Default Re: ITR head on B16 (lsvtecracer)
do you have the itr cams, inatke manifold, throttle body?? if your just installing the head it's not worth it...but yes it bolts on...everything swaps over from the b16 head
Old Dec 18, 2002 | 08:33 PM
Nos4R2's Avatar
Default Re: ITR head on B16 (dohcsideSi)
i have the IM, TB, and cams. i'm thinking of purchasing a used ITR head.
[Modified by Nos4R2, 12:34 AM 12/19/2002]
Old Dec 19, 2002 | 01:15 AM
tony415's Avatar
but why, just p&p the b16a head, it'll be cheaper than getting an itr head. and plus, you could p&p for more better airflow than the techs at acura when they p&p their pr3 heads for the itr.
Old Dec 19, 2002 | 05:05 AM
Nos4R2's Avatar
Default Re: ITR head on B16 (tony415)
i don't know. i thought it would be cheaper to buy a used ITR head than get a P/P job. most of the shops i found charges 800.
umair
Feb 23, 2009 07:09 PM
digital sol
Jan 5, 2006 05:42 PM
JDMlyfestyle
Jan 14, 2004 03:59 PM
nwdave
11
Jul 21, 2003 02:56 PM
