What the heck is wrong with my CAR!!!!
Old Dec 17, 2002 | 06:31 PM
MisterHYBRID's Avatar
Default What the heck is wrong with my CAR!!!!
I'm starting to hate my integra with a PASSION!!! i cant get into any gears at all.
Tranny fluid is full. Someone told me it could possibly be my axles? I have no idea though. Whenver i raise my car the front tires sorta spin by themselves, and the axles have free play meaning i can spin the tire a little before they i actually feel the axle catch into the tranny. I HATE MY CAR! I cant afford to take it into the dealer right now either. PLZ HELP!!!!!!!!!!! any idea, suggestion, comment, would be GREAT!
Old Dec 17, 2002 | 07:06 PM
salbaje's Avatar
Default Re: What the heck is wrong with my CAR!!!! (MisterHYBRID)
either your tranny is bad or your clutch isnt engaging properly
Old Dec 17, 2002 | 07:14 PM
Shawn C's Avatar
In The Garage
Default Re: What the heck is wrong with my CAR!!!! (salbaje)
yeah either synchros are all gone or diff is gone. id recommend buying an itr lds tranny
Old Dec 22, 2002 | 03:57 PM
Default Re: What the heck is wrong with my CAR!!!! (22lbGS-R)
Well the weird thing is, that it after I bleed the clutch completely it'll drive ok for a little bit then it'll mess up again. Someone throw me some possible diagnoses. plz!
is there any way a worn axle could affect the clutch system?
WoRST christmas EVAR
Old Dec 22, 2002 | 04:40 PM
Chiovnidca's Avatar
Are your clutch master and/or slave cylinder leaking?
Old Dec 22, 2002 | 06:01 PM
95siHaTcH's Avatar
Default Re: What the heck is wrong with my CAR!!!! (Chiovnidca)
most likley your clutch is out of adjustment, check the freeplay in the clutch pedal, if there is more than an inch, it is out of adjustment. that right there could cause that easliy by not dissengaging the clutch all the way.
Old Dec 23, 2002 | 05:53 AM
underneath the dash there is some residue under the clutch pedal but it looks real old , and there is about an inch of freeplay. it doesnt seem like any of the transmission components because it happens and then goes away. I think its something causing the clutch not to disengage all the way. what could I check for that?
[Modified by MisterHYBRID, 8:53 AM 12/23/2002]
[Modified by MisterHYBRID, 8:57 AM 12/23/2002]
Old Dec 23, 2002 | 11:37 AM
fbiguy007's Avatar
the master clyinder or slave maybe leaking internaly they maybe worn out
Old Dec 24, 2002 | 06:30 PM
Default Re: What the heck is wrong with my CAR!!!! (fbiguy007)
I dont think its leaking because the fluid level is still even. Would this possibly happen if it was clogged?
Old Dec 24, 2002 | 08:02 PM
hondamastertech's Avatar
you have a damper spring coming loose in the clutch disc causing you intermittent clutch operation, and you will need a clutch master and slave if there is oil residue at the master inside the car.
Old Dec 24, 2002 | 08:49 PM
mmuller's Avatar
Mad Scientist
Default Re: What the heck is wrong with my CAR!!!! (hondamastertech)
your solution is to replace the clutch master and slave cylinder,has happened to my before
Old Dec 26, 2002 | 06:47 PM
fbiguy007's Avatar
no i mean leaking pasted the rubber seals in side= no pressure no pushing on clutch fork
Old Dec 26, 2002 | 06:56 PM
TEAMGENDAI's Avatar
Take you car to someone that knows what they are doing i dont think we can really help online unless we were standing in front of your car, but just make educated guesses!!
Old Dec 26, 2002 | 07:29 PM
pennies_hatchie's Avatar
Default Re: What the heck is wrong with my CAR!!!! (mmuller)
from what you've posted, my best guess would be what this guy said
Old Jan 3, 2003 | 01:23 PM
Default Re: What the heck is wrong with my CAR!!!! (pennies_hatchie)
Just replaced the clutch master cylinder, and the old one felt pretty worn out. Anyways, it still wont shift. Pedal feels ALOT better but it still wont go in gear.
I think the bad master cylinder probably caused something to go wrong with my clutch/tranny. Taking my car to shop tommorow. thanks for all the info guys.
Old Jan 3, 2003 | 01:48 PM
Chiovnidca's Avatar
Did you bleed all the air out of the system?
Old Jan 3, 2003 | 03:49 PM
10K2HVN's Avatar
WHere to get an ITR LSD tranny??? ive been searching and searching but cant find a place or someone who would just sell the tranny!?!?
Old Jan 4, 2003 | 05:18 AM
b19coupe's Avatar
This is the most likely answer to your problem. When the clutch spring breaks out of the hub, it gets jammed and causes the car to act like the clutch pedal is not depressed. Then sometimes the spring will get freed up, and the car will act normally until the next time the spring jams. If your hydraulic system is the problem , the clutch pedal will go to the floor with almost no resistance, or you will have excessive amounts of freeplay.
Old Jan 7, 2003 | 09:38 PM
Default Re: What the heck is wrong with my CAR!!!! (b19coupe)
I bled the system like 10 times just to make sure. I just got it towed in to a shop. I think its the clutch damper spring too, but we'll find out.
mofo951
Jun 9, 2008 03:50 PM
cfoamcvc
Feb 15, 2007 07:17 AM
MDPL8706
Nov 25, 2006 03:11 PM
osiris316
Sep 8, 2003 05:26 PM
IN VTEC
Jun 26, 2003 10:14 PM
