Smells like.....fuel!?!
Old Dec 16, 2002 | 10:33 AM
Goldfingiz's Avatar
Default Smells like.....fuel!?!
Well guys, I started the car just to pull it into my garage to work on it. Immediately it started smoking, so I pulled it in and turned it off. I noticed that it smelled like fuel. I took the spark plugs out, BLACK (running rich =\) I then took the valve cover off, and it was still smoking a little bit (car has been off for a good 15-20min) It also reeked of fuel...any idea what it could be?
I have a B16 w/LS pistons and a custom turbo kit.
Thanks,
Goldfingiz
Old Dec 16, 2002 | 10:45 AM
Desslok's Avatar
Default Re: Smells like.....fuel!?! (Goldfingiz)
Have you checked your fuel pressure? See what the highest it gets is, maybe you blew out your injectors?
Old Dec 16, 2002 | 01:45 PM
Nate B's Avatar
Default Re: Smells like.....fuel!?! (sp)
Check the o-rings on the injectors too, I just had to replace mine after noticing gas floating on my intake manifold
Old Dec 16, 2002 | 01:54 PM
Goldfingiz's Avatar
Default Re: Smells like.....fuel!?! (Nate Bizzle)
Thanks guys...my PVC valve is missing =\
Isn't the PVC system there to release pressure from the motor? Could that be why it's smoking so much? I doubt it, but who knows...
Goldfingiz
Old Dec 16, 2002 | 05:28 PM
Shawn C's Avatar
In The Garage
hey goldfingiz... its pcv, not pvc. pvc is a plastic pipe. pcv stands for positive crankcase ventilation. yes it does let gasses out of the engine. sounds like the problem is that it needs a tune up. the plugs are fouled and its not igniting very much fuel. id get new plugs, wires, cap and rotor. and get ngk stuff, its the best. also check your injector seals. look for fuel everywhere around the fuel system.
Old Dec 17, 2002 | 12:08 AM
Goldfingiz's Avatar
Default Re: Smells like.....fuel!?! (22lbGS-R)
Thank you That can't be the reason why it smokes so much though, can it? Can the PVC system do so much?
Thanks,
Goldfingiz
Old Dec 17, 2002 | 06:20 AM
Desslok's Avatar
If your PCV is missing and the hose is still attached to the IM, then you have a major vacuum leak. A PCV is only a few bucks. Just fix it.
TwinTiper
Apr 26, 2015 03:01 PM
97ek-t
May 1, 2010 10:08 AM
Tunerguy1989
Mar 11, 2010 11:32 AM
j0keefe21
Feb 11, 2009 04:31 PM
bambbrose
Sep 2, 2007 04:58 AM
