what would cause thermostat not to open?
Put it in a pan of water and boil it, you should be able to see it open. If it doesn't take it back. I have seen them bad brand new but usually Stant.
IF THE THERMOSTAT IS NOT OPENING,THE LOWER HOSE IS ALWAYS COLD.
for sale!!!!
bay area only<<<pick-up only<<i got this following stuff for sale:
92 ls motor /trany/ecu for $600 (rebuild motor trany no grinds)
93 prelude motor/trany/ecu for $1000(h23)(motor has 148000 mlz/trany no grind/still good compresion/needs water pump)
95 si trany for $200(no grinds)
92 ys1 trany for $400(da gsr)no grinds
92 integra trany for $200(no grinds)
94 si motor for $250(100000+ mlz)needs head gasket
pwo ecu for $100
cr/vtec motor for $1600. still in the car.no leaks.(b16 head /jdm b20z)
91 integra ls for sale >>$2500 210000+mls.
92 LS HEAD FOR $100
INSTALLATIONS AVAILABLE!!!!!
6505805961
for sale!!!!
pwo ecu for $100
92 LS HEAD FOR $100
6505805961
Was the system clean before you installed it?? I Put in a new thermo one time, but I had all kinds of crap in the system from rusted lines, so it immediately got stuck again with debris.
Since then I have replaced all coolant lines and flushed the system thoroughly
Supa Troopa
19
Feb 29, 2008 08:15 AM
