why is my oilpan leaking???
Old Dec 18, 2002 | 02:47 PM
MeanGreenEG9's Avatar
Default why is my oilpan leaking???
I just installed a new oil pan gasket cuz i thought thats why oil was seeping through the gasket but it is still doing it. I tightend the bolts not too tight all around but oil still seeps through the gasket.. am i doing something wrong? is there some sort of specific sequence you need to bolt those in and is there something other than the gasket i should be using to seal it? thanks in advance.
Old Dec 18, 2002 | 02:53 PM
Jared's Avatar
Default Re: why is my oilpan leaking??? (Junek9)
maybe you're overtorquing the gasket, or maybe the pan is warped. or maybe it isnt your oil pan thats leaking.
Old Dec 18, 2002 | 04:30 PM
tnbigdawg's Avatar
there is a torque sequence, and I always use hondabond around the bolts and on the dimples....Use some around the oilpump case too, as well as the other end of the block.
Old Dec 18, 2002 | 07:19 PM
Default Re: why is my oilpan leaking??? (Jared)
No the oil is definitely leaking from the pan.. i keep wiping it every day and the next day there is more commin out the seams where the gasket is.. I probably am over-torquing.. anyone know the correct sequence?
Old Dec 18, 2002 | 07:24 PM
dohcsideSi's Avatar
did you use an oem gasket???
hondabond is your friend
Old Dec 18, 2002 | 07:37 PM
tominos's Avatar
you also should put on some gasket sealant. that will fix your problem.
Old Dec 18, 2002 | 07:43 PM
Default Re: why is my oilpan leaking??? (dohcsideSi)
Yeah i have an OEM gasket.. I am kind of conffused.. what exactly is hondabond? is it a type of gasket sealent or is that something different?
hondaman211
Jul 22, 2020 06:29 AM
george34
Nov 9, 2016 09:44 PM
JFG Kevin
Jun 19, 2007 07:33 PM
KillerBee18
Jun 22, 2006 11:21 AM
IntegraB18A
Dec 20, 2003 08:18 PM
