need help!!! cant get my diff out, should come out with no problem?
Old Dec 16, 2002 | 09:22 PM
todapower's Avatar
Default need help!!! cant get my diff out, should come out with no problem?
im doing a 4.7 jdm final drive on my type r tranny and i am having trouble getting the diff gear out, it should come right out. i even tryed knocking it out with a mallet from the outer side of the case. its been 2 days and i cant get it to budge... im open for sugestions, i would appreciate any help!!!
thanks...
Old Dec 16, 2002 | 09:30 PM
Kataku2K3's Avatar
Default Re: need help!!! cant get my diff out, should come out with no problem? (todapower)
So are you sayin that the whole diff. is still in the tranny and won't budge??? If so then you may want to try heating the outside of the casing up a bit with a torch... You don't have to do it till it glows.. hehe, just enough to expand the casing... Good Luck..
Old Dec 16, 2002 | 11:22 PM
sgT's Avatar
sgT
if the diff uses the ball type bearing on the diff then you will have to pull straight out
otherwise it will bind and get stuck. just keep trying
Old Dec 17, 2002 | 03:57 AM
Mista Bone's Avatar
D Tranny Guru
just wiggle it.
You'll learn to luv .003" clearance.
Old Dec 17, 2002 | 06:33 PM
todapower's Avatar
Default Re: need help!!! cant get my diff out, should come out with no problem? (Mista Bone)
finaly got it out, just took 2 people, a long peace of wood, and a hammer and after 10 min of hitting it from the outer side of the case, it finaly came out. i dont know why it was so hard, maby the bearing was dry when the diff was first installed.
thanks for everyones help...
RobEK
Jun 3, 2009 08:21 AM
b20beast83
Transmission & Drivetrain
38
Jan 10, 2009 07:55 AM
downest
Jun 19, 2008 01:58 PM
eg6h8k
Jun 21, 2003 12:30 PM
todapower
Dec 17, 2002 04:00 AM
