detonation with nitrous?
Old Dec 15, 2002 | 07:34 PM
lsteggy's Avatar
Default detonation with nitrous?
is it possible to detonate with nitrous? how?
Old Dec 15, 2002 | 07:57 PM
TEGPOWER44's Avatar
Default Re: detonation with nitrous? (lsteggy)
Shooting it too much into ur engine. It causes uneven fuel and air ratios. Too much Oxygen equals detonation. Make sure proper fuel is upgraded before using nawwsss. Also colder spark plugs are required.
Old Dec 16, 2002 | 03:46 AM
sohc_boy's Avatar
too much timing, running lean, crappy gas there are quite a few things that can cause detonation especially wile running nitrous. if u are asking how to prevent it back the timing off and run colder plugs.
Old Dec 16, 2002 | 07:29 PM
lsteggy's Avatar
Default Re: detonation with nitrous? (sohc_boy)
running lean, timing, and crappy gas would cause detonation by them selfs even with out nitrous. what im asking here does the actual nitrous cause detonation?
Old Dec 16, 2002 | 07:35 PM
Shawn C's Avatar
In The Garage
with stock fuel pressure, stock timing, stock octane recommended gas, and stock ignition, yes nitrous does cause detonation. retard your timing a bit, run high octane gas, put in some colder plugs (like a NGK-R BKR7E) and raise your fuel pressure and youll be ok
Old Dec 16, 2002 | 07:43 PM
Norcalstoppy's Avatar
Default Re: detonation with nitrous? (22lbGS-R)
nitrous is FI. same way you blow your turbo car, you could blow your n2o car.
Jay Kim
Old Dec 17, 2002 | 04:01 AM
Mista Bone's Avatar
D Tranny Guru
possible????
I think so!
nitroaccord105
Jul 18, 2007 12:32 PM
SiR831
Jun 28, 2005 10:19 AM
JDM H22
Jun 17, 2005 02:54 PM
ITR981002
Apr 27, 2005 08:51 AM
allshownogo7
Feb 18, 2002 10:19 PM
