ls will not start
Old Dec 18, 2002 | 08:57 AM
speedy-crx's Avatar
Default ls will not start
ok here it is its a 88 dx hatchback with a ls motor and we were doing an engine swap and an auto to manual swap at the same time and i just got it wired last night and at first it wouldnt turn over then we conected all the wires from the old auto stuff in the center between the seats and got it to turn over and it is still spitting code 1 and code 6 does anyone have any idea what it may be
thanks for any help
Old Dec 18, 2002 | 10:53 AM
Perfectionist's Avatar
Default Re: ls will not start (needahatch)
Code 1 - O2 sensor
Code 6 - TW sensor (water temp)
Old Dec 18, 2002 | 10:54 PM
speedy-crx's Avatar
Default Re: ls will not start (Perfectionist)
if those two things are unhooked will it start or not
Old Dec 22, 2002 | 10:01 AM
speedy-crx's Avatar
Old Dec 22, 2002 | 11:22 AM
The TW sensor tells the ECU what temp the motor is at. Without that information, your aiur/fuel ratio could be too rich or lean for the engine to start. The O2 sensor would not be a cause for a no-start condition.
Old Dec 22, 2002 | 11:36 AM
3rdGteg's Avatar
did u move the distributor around to see if it'll start? Maybe timing is way off; just give it a try.
jonney66
Honda CR-V & Element
May 6, 2014 01:24 PM
brians356
Sep 30, 2013 01:59 PM
jdmallmotorhatch
Aug 15, 2008 11:03 PM
crxsteve
Sep 12, 2007 08:06 AM
blufke
Aug 15, 2002 10:15 AM
