wiring schematics
Old Dec 17, 2002 | 09:47 AM
jdmcrx1's Avatar
Default wiring diagrams
Hey guys, I need two things, a wiring table for 89 crx si cluster and a 2000 teg LS. Thanks for all you help; I am doing the ls cluster in my car and the guy who did it in his has a 97 cluster so they are a little different.
Tony
[Modified by jdmcrx1, 9:17 PM 12/17/2002]
Old Dec 17, 2002 | 12:36 PM
Kataku2K3's Avatar
Default Re: wiring diagrams (jdmcrx1)
I found one on here a few weeks back... it was to put a 94+ Teg cluster into a CRX... Well I barely even used it... The diagram was a piece of **** and not accurate at all... I went through all the wires without the diagram and wired them up along with the electronic VSS.... We just put a 95 JDM GSR cluster into my friend's car and it seems to work fine.... If you want i'll try to write up just the pins that you need to know then i'll post them up... Without diagrams it took maybe 3 hours to figure everything out so you should be able to do it a lot faster... If anyone does have the OE wiring diagrams i would love to have them too... that would have made it way fast... Anyways i'll get back... Latez
daymkimchee
Mar 15, 2010 06:09 PM
I8ayellowcrayon
Apr 18, 2007 02:16 PM
racecarpete
Apr 7, 2002 08:06 AM
