too much oil ?
Old Dec 15, 2002 | 05:08 PM
fEAR9's Avatar
Default too much oil ?
i accedentlly put too much oin in my b18
maybe 1 quart or less... will this cause any problems ?
Old Dec 15, 2002 | 05:25 PM
Regular Series's Avatar
Default Re: too much oil ? (fEAR9)
Yes. Drain the excess ASAP.
Old Dec 15, 2002 | 06:28 PM
10K2HVN's Avatar
HAh i accidently did that in my 83 datsun...damn thing was blowing smote like nobodies business..! i think it blew my rings..because the car broke down that month... good times in that car...
Old Dec 15, 2002 | 06:47 PM
Koori's Avatar
Default Re: too much oil ? (10K2HVN)
Yeah, drain some out.. It's weird, I used to have risingson's attitude about this.. Then, my fiancee bought a 97 Prelude from her parents.. Her father did all the maintenance.. He ALWAYS put a quart too much in. Don't know why or how.. But the car has over 110K on it and all the tests (compression, etc) come back near stock.. That one still baffles me to this day..
I was always under the impression that too much oil will cause the crank to drown in oil.. The crank spins, turning up the oil and putting air bubbles into it at the same time.. Frothy oil doesn't lubricate well.. Never heard anything about rings going from too much oil.. Does that have to do with the raise in oil pressure?
Old Dec 15, 2002 | 07:07 PM
Default Re: too much oil ? (Hadji)
Weird. I guess that 'Lude had a large oil pan.
Still, you shouldn't take chances with it.
Old Dec 18, 2002 | 05:45 PM
StorminMatt's Avatar
A LITTLE too much oil (like maybe up to .25 quart or so) doesn't hurt anything. In fact, I frequently overfill my B16A slightly to make it an even 4 quarts so I won't have to deal with a leftover bottle with ~.125 quart. But if you are a quart over, you could have problems.
[Modified by StorminMatt, 2:46 AM 12/19/2002]
Old Dec 18, 2002 | 07:01 PM
tilt's Avatar
Default Re: too much oil ? (StorminMatt)
just look at the dipstick, if it's between the 2 dots you should be ok.
Old Dec 18, 2002 | 07:39 PM
tominos's Avatar
Default Re: too much oil ? (tilt)
yea, i actually have put oil pass the line a little bit, and i just left it and car is still okay.
Old Dec 19, 2002 | 04:21 AM
ryanstev's Avatar
Default Re: too much oil ? (tominos)
With too much oil, the crankshaft whips the oil into a foam, which can stop your oil pump from pumping oil through your engine.
Old Dec 19, 2002 | 05:16 AM
Ricky Rojales's Avatar
Yes, windage... drain some oil out.
SkoundrelUSA
Aug 28, 2004 11:25 AM
redlineSH
Jul 27, 2004 07:32 PM
SupaTegRS
Apr 14, 2003 11:02 PM
Buckshot
Jul 27, 2002 09:47 PM
