Tuning is Everything!
Old Dec 15, 2002 | 06:27 PM
7rrivera7's Avatar
Default Tuning is Everything!
So how do you do it? I have a Zdyne with VTEC and NOS control but I'm all motor right now. I loaded the basic B16 tune but how can I improve it? Where do I start? What exactly is tuning? Setting fuel and ignition tables? How do you do it? Can someone with experience give me some pointers?
Old Dec 15, 2002 | 06:30 PM
eg6ajk's Avatar
Default Re: Tuning is Everything! (7rrivera7)
doesn't zdyne provide some type of a manual with the programmable ecu?
tune the car at first with just what you have. then start plying with the ignition adn fuel maps.
check the timing, check sparkplugs (to see if you are running rich or lean)
Old Dec 16, 2002 | 04:19 AM
7rrivera7's Avatar
Come on tuners! Give up your secrets!
Old Dec 16, 2002 | 09:23 AM
advanracing62's Avatar
you're not going to get a whole lot of info about tuning... it's kind of a secret edge that people have. The only way to learn how to tune is to just do it. Look at your base map and figure out your mods. Then adjust things based on your findings. Every car is different and there is no single answer to your problem
Old Dec 16, 2002 | 10:47 AM
7rrivera7's Avatar
Default Re: Tuning is Everything! (advanracing62)
How do I tune against my mods? For example, I have CTR cams. What and where would I modify to get the best bang for the buck? Ignition? Fuel? Both?
Old Dec 16, 2002 | 11:56 AM
577HondaPrelude's Avatar
get on a dyno!!! it's the only way. U make a change and see how your dyno plots change. Your local dyno should have a wide band o2 sensor they can hook up while your on the dyno, and this should help with trimming the fule map. your not going to need to add much fuel unless your FI, but just get on a dyno and play with settings all day.
Old Dec 17, 2002 | 05:30 PM
delslow94's Avatar
Default Re: Tuning is Everything! (57STS)
alright someone said it. this is the best and only way to tune ur car imo
raverx3m
Engine Management and Tuning
Jan 25, 2016 10:53 AM
raverx3m
Jun 4, 2013 03:27 PM
vestalfootball72
Dec 18, 2007 08:11 PM
R-Toyz.com
May 20, 2003 12:58 PM
Short_Shifter
Mar 27, 2002 06:18 AM
