Turbo Guru's, Customize me a setup!!
Old Dec 16, 2002 | 10:27 AM
BluFire's Avatar
Default Turbo Guru's, Customize me a setup!!
Ok, I have a 94 GSR (right now with just AEM cam gears, CAI and a 2.5" exhaust) I just bought, and Im looking to put together a turbo kit that will boost no higher then 10 psi, no less then 5psi. What would be a good "bang for the buck" setup? I want it to be intercooled as well. Should I just splurge for the Greddy or DRAG kit? or could I piece together an ideal setup for this by piece cheaper? I really need some expertiseo n this matter, any help or suggestions appreciated.. Thanks guys!
Old Dec 16, 2002 | 10:31 AM
Goldfingiz's Avatar
Default Re: Turbo Guru's, Customize me a setup!! (BluFire)
Not to sound like an ***, but get some low compression pistons/rods first and expect the unexpected because **** happens.
Goldfingiz
Old Dec 16, 2002 | 10:39 AM
BluFire's Avatar
Default Re: Turbo Guru's, Customize me a setup!! (Goldfingiz)
YEa, Ive spoke to a friend of mine that builds race motors and he said not to bother with low compression stuff for boost that low. The stock internals on the B18C1 will handle 8psi no problem. Im not lookin to build a track monster, just a street driveable with a little extra kick..
Old Dec 16, 2002 | 12:02 PM
577HondaPrelude's Avatar
yup, the right way to set up a car for turbo is to lower the compression. However, if your not going to go this far U will at least need to dyno tune the car and get the A/F ratio fixed with FI. Tuning your car is a must if your going FI.
Old Dec 16, 2002 | 12:04 PM
BluFire's Avatar
Default Re: Turbo Guru's, Customize me a setup!! (57STS)
I got one of the best tuners in Eastern Canada doing the tuneing for me so I have that covered. I wasnt going to just slap it on and go Can anyone post pics of there setup and a roungh cost for it?
Old Dec 16, 2002 | 12:18 PM
Shawn C's Avatar
In The Garage
look mang, go buy a greddy kit w/ intercooler and blow off valve. its a bad *** kit, and for now i might recommend a low compression head gasket. (bear with me here guys) piecing together a turbo kit is usually more expensive than buying a complete kit. i had the basic greddy kit on a 98 gs-r, plus low comp. je pistons/ eagle rods, and a b16a head. but i had an xs engineering intercooler, hks blow-off valve, and a bunch of other stuff. it was soooo damn expensive. so for just running 7 or 8 psi, i would recommend just buying a kit. get the greddy, its beautiful.
acura_b18c1
Sep 4, 2012 03:36 PM
Smily0087
Mar 20, 2010 05:37 PM
jdmmachine
May 1, 2007 08:01 AM
TurboTeG4
May 10, 2003 08:02 PM
PainfulTeg
Oct 24, 2002 01:39 PM
