Is one long blink a code 10 or 1?
Old Dec 16, 2002 | 10:08 AM
bumpin_bass's Avatar
Default Is one long blink a code 10 or 1?
Check engine light is throwing one long blink. Is this 1 or 10? I am sure this will be easy to answer. Thanks in advance.
Old Dec 16, 2002 | 10:37 AM
Spade's Avatar
Default Re: Is one long blink a code 10 or 1? (bumpin_bass)
Is it repeating it?
Or is it 1 long blink followed by a bunch of short ones?
Long blinks are 10's and shorts are 1's
I.E. _ _ _ _ ..... Is 45
Old Dec 16, 2002 | 12:41 PM
Default Re: Is one long blink a code 10 or 1? (Spade)
It is just one long blink. A couple seconds go by and then it blinks once again. etc.
Old Dec 16, 2002 | 01:02 PM
Spade's Avatar
That usually means the ECU
Old Dec 16, 2002 | 01:10 PM
Damn, what does a code 1 look like then, and what does code 10 look like? Thanks for helping. It has thrown other codes, but I got those fixed. Are there any other symptoms of a bad ECU.
Old Dec 16, 2002 | 01:14 PM
Kamin's Avatar
actually if he is describing this right, its code 10, wich is the intake air temp sensor.
Old Dec 16, 2002 | 02:06 PM
Default Re: Is one long blink a code 10 or 1? (Kamin)
Where exactly is this sensor located? I have a second gen JDM B16a.
Old Dec 16, 2002 | 03:16 PM
Shawn C's Avatar
In The Garage
its on the third runner from the left. its a little oval sensor with the 2 prong plug on the top. its 2 screws on it and has a plastic rod in the intake about .75" long.
Old Dec 16, 2002 | 03:57 PM
Sonny's Avatar
That stupid code caused me a lot of grief on the dyno once. One long blink...I thought it was a code 1 (Oxygen sensor), but it was actually the IAT sensor. I was working under the hood between runs and I knocked the connector loose.
Sorry...no helpful info...just thought I'd rant. Honda really should not have used a code 10!
Sonny
Old Dec 16, 2002 | 05:40 PM
salbaje's Avatar
yes if its constantly on then that would be ecu but if it blinks long and does it over its the iat. its on top of the intake manifold.
Old Dec 16, 2002 | 07:45 PM
Default Re: Is one long blink a code 10 or 1? (salbaje)
Thanks, I will check that out in a couple of days.
Old Dec 17, 2002 | 12:48 PM
Hey could the intake air temp sensor affect my thermostat, or is it totally unrelated. Here is my thread about the thermo prob https://honda-tech.com/zerothread?id=355213 Thanks
Old Dec 17, 2002 | 02:53 PM
salbaje's Avatar
sounds like thermostat isnt opening up. change that and bleed the coolant properly and see if it makes difference
Old Dec 17, 2002 | 06:53 PM
iwhichisme's Avatar
one long beep is a 10. If thats the only code it should repeat itself after a while. 1, would be a short blink.
jchrm80
Feb 6, 2008 02:18 PM
mikegeezy
Oct 3, 2006 05:42 PM
THE94GSR
Jun 25, 2004 05:07 AM
RRRex
May 7, 2003 05:06 PM
SOUTHCREX
Sep 24, 2002 04:35 PM
