Is this normal ?
Old Dec 16, 2002 | 10:43 AM
RCautoworks's Avatar
Default Is this normal ?
Let me start off by saying I am probably just pairnoid, ok my question is. I start my car and my oil light lites up for about 2 second then shuts off. Someone told me its suppose to shut off right away, if not my oil pressure could be low. Just curious about what you guys think.
Old Dec 16, 2002 | 10:54 AM
Spade's Avatar
Default Re: Is this normal ? (90blackcrx)
No it's not normal. It should shut off right away. What's your oil level at?
Are you checking your oil when the car is warmed up or cold?
Warm should be your answer.
Old Dec 16, 2002 | 01:23 PM
Default Re: Is this normal ? (Spade)
I check the oil when the car has been sitting for a while, so yes that would mean cold. Last time I checked the oil leval was right at the top dot. The light comes on then shuts off, I think I am just pairnoid.
[Modified by 90blackcrx, 10:31 PM 12/16/2002]
Old Dec 16, 2002 | 05:32 PM
Shawn C's Avatar
In The Garage
i might try and flush the engine out, too. just drain it, put in 3.5 to 4 quarts of auto tranny fluid ( dextron III with mercon) start it and let run for like 10-15 min, drive it around if you want to, revving it up good, then drain it and change the filter. refill with some 10-30 pennzoil or valvoline (maybe valvoline maxlife) and you should have much better oil pressure. btw- atf is just really thin motor oil with a lot of cleaning additives in it. this wont hurt anything.
Old Dec 16, 2002 | 06:37 PM
GZERO's Avatar
Default Re: Is this normal ? (22lbGS-R)
have you done this before? where did you got it from? it sounds intersesting but i would be affraid of doing this, any info you have could help to have some confidense
Old Dec 16, 2002 | 11:48 PM
tnbigdawg's Avatar
if it shuts off right away, then its normal. i would never run auto tranny fluid in my engine....its just not thick enough.
Old Dec 17, 2002 | 12:42 AM
Goldfingiz's Avatar
You're supposed to check oil when the car is cold =\
Goldfingiz
Old Dec 17, 2002 | 06:25 AM
Spade's Avatar
If you check it when the car is cold all of the oil will be in the oil pan and you won't get an accurate reading. YOu need to check when the car is hot, like when you are at a gas station filling up or something......not immediatly after you shut the engine off but no more than 5 minutes.
Old Dec 17, 2002 | 07:49 AM
Razor's Avatar
i've learned from everyone that you check engine oil when its cold, and transmission fluid when warm. all the techs at honda tell me this too.
Old Dec 17, 2002 | 08:40 AM
Charlie Moua's Avatar
hey i have the same issue. I have a 90 civic si. I lights up for like 1 sec, that's it.
I haven't had any problems though.
TTT for anyone who knows how to fix this. I jut in like 4.3 quarts of mobile1
Old Dec 17, 2002 | 09:19 AM
NonovUrbizniz's Avatar
Loved
Default Re: Is this normal ? (Charlie Moua)
my civic oil pressure light comes on for a second or two then turns off.
if there is a problem with the pressure the light will stay on.. these guys are all paranoid too apparently.
ninjaturtleEG
Oct 24, 2016 06:20 PM
97RedHatch
Sep 30, 2013 03:49 AM
Ownage1100
Jul 27, 2008 09:56 AM
tegs94
Oct 11, 2006 02:00 PM
Mario.
Dec 23, 2004 09:03 AM
