Over Reving?
Old Dec 17, 2002 | 02:57 PM
dgdarien's Avatar
Default Over Reving?
Okay we all know one shouldn't rev their engines into the red zone as this may cause damage. But something I'd like to know is what exactly causes damage? Are the RPMs just too high for the engine to be able to withstand?
Old Dec 17, 2002 | 03:10 PM
mmuller's Avatar
Mad Scientist
Default Re: Over Reving? (dgdarien)
valve float;valve springs cannot move the valve up fast enough,boom,valves hit the pistons.
damn i wrote valves 4 times
Old Dec 17, 2002 | 03:13 PM
Type Wah's Avatar
Default Re: Over Reving? (mmuller)
what u have a rev limiter of 7500 rpm? is it still dangerous to go in the red zone?
Old Dec 17, 2002 | 03:18 PM
mmuller's Avatar
Mad Scientist
Default Re: Over Reving? (Type Wah)
what is the red zone to you, what rpms?
Old Dec 17, 2002 | 03:34 PM
kreeme's Avatar
actually, u wrote it 5 times
Old Dec 17, 2002 | 05:42 PM
tominos's Avatar
Default Re: Over Reving? (kreeme)
yep 5 times
Old Dec 17, 2002 | 06:30 PM
mmuller's Avatar
Mad Scientist
Default Re: Over Reving? (tominos)
i know the last one didnt count
Old Dec 17, 2002 | 07:13 PM
dgdarien's Avatar
hahah okay yeah there's lots of valves, we got that understood. So is that really the only cause of engine damage when over reving an engine past it's redline? Or is there anything else that occurs to cause some sort of irreversible damage?
Old Dec 18, 2002 | 12:53 AM
Lsos's Avatar
This graph shows that at 8000rpms, a b16s pistons are accelerating at around 3500g's. That means that if the pistons weigh 1lb, then they "weigh" 3500lbs at 8000rpms. That's how much force the rod has to supply to the piston to accelerate it down from TDC.
You'll also see that the acceleration grows exponentially, so at 16000 rpms the piston would "weigh" 14000 lbs. Obviously ****'s gonna get ****ed up before then, as the rod is only designed to handle 3500lbs. The same goes for everything else that rotates. Also, the valves float because their "weight" increasees as they accelerate faster and faster, until the weight overcomes the springs and the valves jump off the cams....
Side note, I heard Ferrari uses or used controlled valve floating to their advantage, sort of like a vtec system, if you will. They called it ballistic something or other. That's pretty sketch if you ask me
[Modified by Lsos, 9:55 AM 12/18/2002]
Tutu
Aug 21, 2005 04:42 PM
Littlegreend15
31
Jun 3, 2005 08:11 PM
rice4life
Jul 24, 2003 09:45 PM
austrian type-R
Oct 8, 2002 08:27 AM
Veil_Side_
Oct 11, 2001 05:38 PM
