Whats the general procedure for a dyno run?
start with a baseline run then adjust air/fuel fuel pressure boost whatever and try and bring things to ideal or peak you got to be more specific with question!
what gear to run a 96 gsr in. i have slightly bent valves and limited mods and i still goe 160.1 corrected to the wheels. this seems high for a car with only a catback regulator dunk exhaust and dc 4 2 1 header at the time and the venom 400 control module wich made an almost 10 hp peak gain from a baseline of 150.4 all in fouth gear. is this the gear to use.
CRX A4
20
Aug 6, 2003 11:02 AM
