H22a Question?
Old Dec 19, 2002 | 09:15 PM
blackedoutcivic's Avatar
Default H22a Question?
how can you tell if a motor is the dreaded SH motor. i am supposed to go and look @ an h22a (came out of a 2001 prelude) i want to know what to look for.. warning signs etc.. please help me out!! post here or email
shaneengland@charter.net
thanks!
shane
Old Dec 19, 2002 | 09:49 PM
satan_srv's Avatar
Default Re: H22a Question? (blackedoutcivic)
The block will say H22A4
And the stamp on the cylinder head just above the exhaust ports will say P5P. P5P should also be just above the oil pan. And the oil filter will be like in the stupidest place ever
Old Dec 20, 2002 | 01:06 AM
texan's Avatar
Default Re: H22a Question? (satan_srv)
Hahahaha!! Yeah, I just luuuv changing my oil.
All 5th gen USDM H22's will be H22A4, but there's one sure way to tell the difference between SH and non-SH motors. On the extended engine code (i.e H22A4-x<u>x</u>xxxxxx) the second x digit will be a 5 if it's an SH, and a 0 if it's a Base model.
Old Dec 20, 2002 | 03:00 AM
Default Re: H22a Question? (texan)
so what is so terrible about the SH h22a's when swapping them into a civic??
shane
Old Dec 20, 2002 | 10:28 PM
SuperSH's Avatar
The tranny wont work out, the shafts are diffrent. You wont be able to use the ATTS (sh portion of the tranny) since you wont be able to use any of the sensors that it requires to operate (yaw, steering angle, tranny oil cooler, etc, etc). So you carrying arround about 45 extra pounds of metal that dosent do anything. In order to use a base tranny you have to modify the tranny to accept the diffrent bolt pattern to bolt to the engine. I dont think the diffrent location of the oil filter would be of factor but it does sit a bit higher (6 inches higher) than the base model. Just do yourself a favor and use a base model 5-spd. much easier and less hassle.
PR 93EG
Aug 31, 2005 11:02 AM
Slipknt777
Jul 12, 2004 03:16 AM
blackedoutcivic
Dec 21, 2002 08:30 AM
Steppin Razor
Aug 11, 2001 09:42 AM
