catch can
Old Dec 19, 2002 | 11:20 AM
nerdsports's Avatar
Default catch can
after removing a couple intake manifolds from several sohc engines.... i decided i should get myself an oil catch can. just looking into a manifold is like whoa!!! another thing, i removed my a/c so this is where i got my idea. the lil can thats mounted in front of the drivers side tire with the pipes....... i cut it open and removed the material inside. i used the stock piping that was on it and cut em like 3 inches long.... i got the can welded back together for $5 and got the hose and 4 lil clamps for $9. so in total $14. here are the pics of my supplies. will be installed today. and pics will be posted later as well.
[Modified by nerdsports, 8:23 PM 12/19/2002]
Old Dec 19, 2002 | 01:54 PM
Tbone's Avatar
Default Re: catch can (nerdsports)
Nice diy, but dont use that clear hose, when it heats up it will collapse under vaccume. I know this first hand. One more thing, what did you bafffel it with and where is the drain? Funny, i mounted my moroso can in the original location of where your can came from
I used aircraft fuel line.
If you look close you can see my drain sticking down on the right hand side in front of the radius rod(the brass looking thing)
Old Dec 19, 2002 | 04:02 PM
nerdsports's Avatar
Default Re: catch can (Tbone)
it was welded shut before i baffled it. did more research afterwards and theres no drain yet.... imma drill a hole and put a valve......
installed it a while ago. no oil in hte clear hoses yet.... i will see how the hoses hold out... i put some thermo-wrap on a section that was near the radiator hose....... will post pics tomorrow.
Old Dec 19, 2002 | 09:46 PM
JalopySiR's Avatar
So ummm, I was a autozone the other day... picked up a fuel filter. Plastic. Cup shaped. Intlet/outlet on top. Put it inline between manifold and valvecover... Car hasn't exploded yet. This is purely experimental. $1.99...
Old Dec 20, 2002 | 10:59 PM
XDEep's Avatar
Default Re: catch can (JalopySiR)
heres mine
hes right about the reinforced pvc, itll collapse. regular fuel line hose is fine.
Old Feb 6, 2003 | 10:30 PM
beedoublejay's Avatar
where did you find that clear hose at?
Old Feb 7, 2003 | 07:05 AM
Jeff C's Avatar
Default Re: catch can (beedoublejay)
Where did you get that at? Will regular auto fuel line work too?
Home Depot has it in the plumbing department.
SMOOTHN
Welding / Fabrication
12
Aug 1, 2010 01:32 AM
Romo Pyro
Aug 25, 2009 02:26 PM
2point2
43
Jul 22, 2007 12:19 AM
boostincoupe
Apr 13, 2006 09:37 PM
bennjamin@ozhonda.com
Feb 26, 2005 06:12 AM
