Balancing bottom-end,
Old Oct 18, 2002 | 05:28 PM
migo's Avatar
New User
Default Balancing bottom-end,
What If I just balanced the Crank,Flywheel and Pulley, am I safe..
I shotpeened the rods and using over-size US specs Type R piston on a LS block
Old Oct 18, 2002 | 06:30 PM
GZERO's Avatar
Default Re: Balancing bottom-end, (D.SPECS)
what is your question?
Old Oct 18, 2002 | 06:52 PM
3rdGteg's Avatar
Default Re: Balancing bottom-end, (GZERO)
U might as well get the pistons balance with that crank and be complete.
Old Oct 19, 2002 | 12:16 AM
miller's Avatar
Default Re: Balancing bottom-end, (3rdGteg)
to have it done correctly you should have the whole bottom end balanced together
Old Oct 19, 2002 | 01:21 AM
ninesecrx's Avatar
Default Re: Balancing bottom-end, (vtecdoc)
If you were using all brand new parts, you would be plenty fine on just balancing the crank. The pistons and rods would be in spec from the factory and the oil on the rotating mass would throw it off more then anything anyways. You should be fine in my opion...If you were to worry about anything, it would be the rods off weight. I think your fine and if you not gonna try for big hp and high reving which it seems your not, then your fine.
Old Oct 20, 2002 | 07:53 AM
migo's Avatar
New User
Default Re: Balancing bottom-end, (ninesecrx)
I'm still using the Ls rods, an since the LS block was meant to rev up to 6800. I justwanna be safe that I can rev up to 8k
Old Oct 20, 2002 | 02:08 PM
BudaKai's Avatar
Hehehe snap--- boom-------- bang!!!! What was that!?
Old Oct 20, 2002 | 02:35 PM
migo's Avatar
New User
Default Re: Balancing bottom-end, (tzsir)
Sound like you've this before
94civicgsr
Mar 6, 2011 08:00 PM
theme
11
Mar 11, 2009 05:06 PM
prodragEG
Jun 8, 2008 08:54 PM
TurboEH2
Apr 2, 2005 11:15 AM
genius
Dec 2, 2002 10:16 AM
