JDM b16a1 coming!! What to replace?
Old Oct 15, 2002 | 06:44 PM
Rydaddy's Avatar
Default JDM b16a1 coming!! What to replace?
Okay, I actually know what I am going to replace - timing belt, thermostat, alternator belt, spark plugs/wires, distributor cap/rotor, valve gasket, clutch/flywheel, header, upper and lower radiator hoses, and the water pump and tensioner pulley (did I forget anything?). My REAL question is: Is there a place on the internet that I can go to to purchase a tune-up package? I remember seeing one somewhere that came with a few of those things, but i cant remember where. Im trying to simplify my life since I already have stuff coming from like 4 different sources. Thanks!
Old Oct 15, 2002 | 08:42 PM
976's Avatar
976
New User
Default Re: JDM b16a1 coming!! What to replace? (Rydaddy)
I would only use genuine honda parts. Sorry I forget the direct link.
You should try Toda's new timing belt.
Old Oct 16, 2002 | 01:01 AM
BudaKai's Avatar
Default Re: JDM b16a1 coming!! What to replace? (w00t!)
Check the valve train out. Compression check. I'd relace the oil pump to, but that's my thought on the fact that just about every car that I have seen in pictures from over there is modded and possibly raced. Hopefully you ordered from reputable importer and I believe you did. I can't think of anything else.
Old Oct 16, 2002 | 06:47 AM
Booger's_Rex's Avatar
Default Re: JDM b16a1 coming!! What to replace? (tzsir)
inlinefour.com has a water pump and timing belt combo. all oem parts for a reasonable price. also make sure you check your sensors. my tps was all messed up so we hd to adjust it to get it to run right. good luck
Old Oct 17, 2002 | 07:38 AM
Rydaddy's Avatar
Default Re: JDM b16a1 coming!! What to replace? (Booger's_Rex)
Awesome....i think i remember seeing that water pump/timing belt combo there now. Thanks!
[Edit]: If i am getting a jdm b16a gen1, should I order the package for the DOHC delSol or for the 99-00 Si, or does it matter?
[Modified by Rydaddy, 4:43 PM 10/17/2002]
Old Oct 17, 2002 | 08:06 AM
EP3_05's Avatar
Both the 99 Si parts and the 94+ Dohc Del Sol parts will work since both have generations of the b16a.
Old Oct 17, 2002 | 05:54 PM
Rydaddy's Avatar
Default Re: JDM b16a1 coming!! What to replace? (91civic)
Thought so....inlinefour.com gives you the option for either the del Sol DOHC or the Si...kind of weird since they are the same Thanks for confirming that though.
Old Oct 17, 2002 | 06:03 PM
sleepycivix's Avatar
http://www.acuraautomotiveparts.net/
and
http://www.hondaautomotiveparts.com/
have a good day
Old Oct 18, 2002 | 02:49 AM
evo's Avatar
evo
New User
Default Re: JDM b16a1 coming!! What to replace? (sleepycivix)
Would the B18C ITR oil pump/water pump work in B16, are they has the same capacity??
Old Oct 18, 2002 | 07:50 AM
myhatchrips's Avatar
timing belt,water pump,alternator belt,thermostat,spark plugs,distributor cap and rotor,oil,tranny fluid,coolant,pcv valve,valve cover gasket. no need to change the headgasket. peace
webster426
Honda Civic (2001 - 2005)
Jul 6, 2009 05:06 PM
matryx
Jul 16, 2007 04:45 PM
1999gs-r
Apr 26, 2006 09:56 PM
SamC
Mar 4, 2003 12:16 AM
nek0
Sep 26, 2002 10:46 PM
