Where do you find MTF????????
Old Oct 15, 2002 | 12:42 PM
HybridHatchC1's Avatar
Default Where do you find MTF????????
I need some manual transmission fluid before i run my new swap, i bought the new oil,clutch fluid and hoses now all i need is MTF any suggestions?
Old Oct 15, 2002 | 12:43 PM
EP3_05's Avatar
Default Re: Where do you find MTF???????? (Civ-JDM)
You can buy it from the dealer... http://www.inlinefour.com sells Honda MTF
Old Oct 15, 2002 | 01:59 PM
3rdGteg's Avatar
Default Re: Where do you find MTF???????? (91civic)
The Honda Dealer always got em. 3-4 bucks a quart; you'll need a little over 2 quarts so buy 3 bottles.
Old Oct 15, 2002 | 03:32 PM
tinkerbell's Avatar
Default Re: Where do you find MTF???????? (3rdGteg)
use Honda MTF Plus.
i used to use castrol stuff, but jsut recently put Honda MTF Plus in and it is soooo much smoother than before!
t..
Old Oct 15, 2002 | 05:02 PM
ransack's Avatar
Default Re: Where do you find MTF???????? (tinkerbell)
i used the 80/90 gear oil...they said its the same
Old Oct 15, 2002 | 05:04 PM
tinkerbell's Avatar
Default Re: Where do you find MTF???????? (ransack)
yes, they say it is the same.
but it is not.
i think Honda use some sort of secret...
t..
Old Oct 15, 2002 | 09:23 PM
TodaCivic's Avatar
I too believe Honda's formula is diifrent.
I used Mobil 1 80w90 and it was good till it got hot.
Honda MTF tho is just as good as when i replaced it 15k ago.
I'd stick with it, plus for 12$ its not a bad deal for 3 quarts.
Old Oct 15, 2002 | 09:44 PM
Mario_D's Avatar
As every prior post to mine, go to the dealer. I've used only Honda MTF in my tranny. It shifts very nicely. For lack of a better phrase...."Like butta!"
mario-
Old Oct 15, 2002 | 10:05 PM
the DR.'s Avatar
Default Re: Where do you find MTF???????? (Mario_D)
you guys are using gear oil in your trannys? honda recommends 10w30 if you cant get honda MTF
i always use honda MTF
Old Oct 15, 2002 | 11:24 PM
Kamin's Avatar
haha
ever looked at/smelled honda MTF compared to oil?
its not the same.
for starters honda mtf is RED.
whoever told you its the same is very wrong.
its very diffrent and MUCH better for the transmission.
Old Oct 16, 2002 | 04:30 AM
BROOD's Avatar
Honda/Acura dealer or supply source. Honda MTL is the only thing I would ever use in my car. Last time I bought MTL it was around $3-4 dollars a quart, but I bought it by the case for some discount.
[Modified by SLPR, 5:31 AM 10/16/2002]
Old Oct 16, 2002 | 05:33 AM
jweller's Avatar
Default Re: Where do you find MTF???????? (KAMiN)
its not the same.
yeah and the honda mtf stuff smells like mineral oil, not regular motor oil.
buy the Honda stuff
esoterEK..
Honda S2000
Feb 13, 2010 07:41 AM
irollerblade
Mar 22, 2009 10:43 PM
kirbyman
22
May 20, 2008 07:28 PM
95GS-R
Sep 14, 2002 04:48 PM
NighthawkR184
Dec 7, 2001 04:28 PM
