requesting info for a swap in my '85 REX
I am looking for the most easiest engine/transaxel swap into car. The REX is HF? Carb. 1.5L that I thought was just a headgasket that was bad. Come to find out that I overlooked a small/tiny crack in the head, thus I need to do something. Not looking to spend a fortune in mounts, half-shafts... no more than need be. Looking fo the least bit of mods. needed.
Unless you replace the engine with the same kind, you will need axles and everything else. The steerigng knuckles have a different size hub that doesnt fit. You need rex si parts. Otherwise, 86-89 integras have everything you need. Engine to rear disk, just find one of those and go to work.
KyonMechburg
Aug 3, 2018 05:36 PM
Moon Ill
Jun 16, 2005 04:23 AM
dipillo
May 1, 2005 01:11 PM
cjh_army
Nov 11, 2004 09:53 AM
