Help
Old Oct 19, 2002 | 02:47 PM
Inaniac's Avatar
New User
Default Help
Ive got the engine and tranny apart.... but i cannot get the clutch to clear the bottom of the bell housing... unfortunately Im doing this by myself and dont have anyone locally that can help.... but What do I have to do now to get the clutch out of the bell housing... I can get it clear on the top... just not the bottom.... arggh!
Old Oct 19, 2002 | 04:05 PM
Chiovnidca's Avatar
Default Re: Help (Inaniac)
Did you remove the lower cover?
Old Oct 19, 2002 | 04:14 PM
94gsr's Avatar
What are you trying to do?
Old Oct 19, 2002 | 06:37 PM
Inaniac's Avatar
New User
Default Re: Help (94gsr)
Sorry ... Im trying to pull the engine so I can drop in my new one.... what exactly do you mean by lower cover ??
Old Oct 19, 2002 | 07:29 PM
Chiovnidca's Avatar
I thought you had them out of the car. My bad. I usually pull the engine and trans out together on five speeds.
Old Oct 19, 2002 | 08:43 PM
Inaniac's Avatar
New User
Default Re: Help (Chiovnidca)
every says i dont have to do that though... and man it would be a serious pain in the *** to do now that everything is undone.....
Old Oct 20, 2002 | 02:53 AM
EK MONEY's Avatar
u are most likly gonna want to pull that all out at once. That is the easy way to do. Resecure your tranny and yank it!
Old Oct 20, 2002 | 06:15 AM
94gsr's Avatar
Are you trying to pull the engine out the top, or drop it through the bottom?
Old Oct 20, 2002 | 10:06 AM
Inaniac's Avatar
New User
either way i dont care! i just want it out.... although ive found the cause of all my sorrow i believe... im just going to remove the driver side axle.... there is a lil thin black plate around the bottom of the bell housing that is blocked by said axle.... anyone know what that is called ? anyways as soon as i get that damn axle out... grrr pain in the ***... then i should be able to pull it out of the top.... btw i simply unbolted the tranny from all the mounts so that i could just lower it some..... that seems to have helped also.... thanks for everyones suggestions... please keep them comming!
Old Oct 20, 2002 | 10:54 AM
Chiovnidca's Avatar
Lower cover maybe?
Old Oct 20, 2002 | 11:35 AM
Inaniac's Avatar
New User
It's Time!!!!! FINALLLY! ::backflip::
Its about f*&king time!!!
Old Oct 20, 2002 | 12:15 PM
Inaniac's Avatar
New User
Anyone need a stock fuel rail from a D16 ?
paul anzalone
Honda Civic (2001 - 2005)
Oct 21, 2013 07:51 PM
92civicx
Jan 30, 2009 05:31 AM
chrisyaj
May 15, 2008 05:51 PM
whagkangmakulet
May 11, 2003 08:57 AM
