Help with tranny fluid with kaaz lsd
Old Oct 18, 2002 | 06:00 PM
na96gsr's Avatar
New User
Default Help with tranny fluid with kaaz lsd
Im getting a 95 jdm itr tranny, and it has a kaaz lsd in it. I was told by the seller that I had to use kaaz tranny fluid or i will ruin the lsd. Is this true? I went on the site and the fluid was a 80w 90. Can I get another brand with the same 80w 90 or does kaaz only make this?! I want to have everything so when my tranny gets here I can put it in. If I do need the kaaz fluid, I need to get it ordered so it will be here when my tranny is. Also I was told by the seller that I had to change the fluid every 6 months? Whats the deal on this? Is this true?
The tranny is going in a 96 gsr, and I have never done a tranny swap before. So if anyone knows of all the stuff I need to round up for the swap. It would be greatly appreciated.
Old Oct 19, 2002 | 08:44 AM
maddog2200's Avatar
Default Re: Help with tranny fluid with kaaz lsd (na96gsr)
Just make sure that the fluid you get has an additive for LSD's
-MD
Old Oct 19, 2002 | 10:05 PM
Mista Bone's Avatar
D Tranny Guru
I used the Kaaz fluid for the break in, then drained per instructions. Refilled with Kaaz fluid again for first 3,000 miles. Now running Coastal (Autozone brand) 80w90 gear oil and 3 oz. of Limited Slip additive.
Kaaz LSD always feels HARSH when cold, some chatter after backing out of driveway. Once tranny oil is warmed up all is good. The ONLY problem I've had some far, is going arond corners in the wet. LSD lock under power, inside tire start spinning. I will NEVER try to drive in the snow with current setup.
[Modified by Mista Bone, 2:05 AM 10/20/2002]
Old Oct 19, 2002 | 10:38 PM
5 Skware's Avatar
I missed the boat
Default Re: Help with tranny fluid with kaaz lsd (maddog2200)
I have a mechanical LSD like the KAAZ (Spoon Sports) and yeah some chatter is common with them but make sure you run the right fluid and you can put in a additive to the fluid to eliminate a lot of it. Also you definetly should change it a lot more often than regular tranny fluid. Definetly worth the extra hassle
Old Oct 20, 2002 | 08:54 PM
na96gsr's Avatar
New User
Default Re: Help with tranny fluid with kaaz lsd (Mista Bone)
My tranny is used, so can i get away with using that coastal gear fluid from auto zone when i put my tranny in? Does autozone carry that limited slip additive also??
How often should I change the tranny fluid once i install this tranny? How much does that kaaz fluid run? And where is a good place to get it?
That sucks that driving in the snow is not good, cuz it snows up here in Idaho!
Old Oct 20, 2002 | 08:56 PM
na96gsr's Avatar
New User
Default Re: Help with tranny fluid with kaaz lsd (EGCIV)
What fluid are you running with your tranny EGCIV? Are you running the kaaz fluid? Or another fluid?
Old Oct 21, 2002 | 06:05 AM
satan_srv's Avatar
I'm using Kaaz gear oil, I don't really want to mess with it....2 years and running strong
Old Oct 21, 2002 | 10:45 AM
advanracing62's Avatar
Default Re: Help with tranny fluid with kaaz lsd (satan_srv)
Maybe you should let Dietz automotive install the tranny. While you're at it put a 3 puck ceramic faced plate in there with a super high sprung hub... mate that to the lightest flywheel you can and then drive like a mad man for about 3k. Then when your final drive shatters you can do this all over again!!!! (sergio likes this!!! )
Old Oct 21, 2002 | 11:23 AM
satan_srv's Avatar
Default Re: Help with tranny fluid with kaaz lsd (advanracing62)
Bad luck eh? Sucks
Old Oct 21, 2002 | 04:51 PM
na96gsr's Avatar
New User
How much does the kaaz gear fluid run? And whats the best place to get in on the net???
Old Oct 21, 2002 | 05:05 PM
5 Skware's Avatar
I missed the boat
Personally I use the Redline brand fluid, but any brand that is specifically made for gear type LSD's should be fine. Also I change my fluid every other oil change (between 5000 and 6000 miles).
Old Oct 22, 2002 | 06:28 PM
It's Blue's Avatar
New User
Advanracing62 what is the problem with Dietz automotive??? I have heard that they do extremely good work and have always come highly recommended to me by numerous people here in Bosie.
Old Oct 23, 2002 | 06:32 PM
na96gsr's Avatar
New User
Default Re: Help with tranny fluid with kaaz lsd (It's Blue)
Yea Advanracing62, what is the problem with your buddy Gregory Dietz?? "Extremely" good work, and always "highly" recommeded by numerous of pEEps in the greater Boise area! Im gonna have to give you a SERG style beating of the heads... ---->advanracing
Old Oct 23, 2002 | 06:36 PM
na96gsr's Avatar
New User
BTW the tranny arrived today! I will be using a combination of the Coastal gear fluid 80W90 and limited slip addictive. It wont be put in untill the end of the week/first of next week. So I'll post the results when i get it in. RULE!
Sergeo and TIm for not likeing sKuNK2!
Old Oct 23, 2002 | 07:14 PM
what part of my post did you not get? Perhaps it was the mis-match of a clutch to the car it was being put it in...... But who's to say?
Old Oct 23, 2002 | 07:16 PM
It's Blue's Avatar
New User
HMMMmmm,, Ok I guess that I am missing something and out of the loop with the whole Dietz Automotive thing. So enlighten me fellow Boise people what's up with them???? Something bad that I have not heard about yet, a$$hole, thief, or something of that nature??? What is the problem??
Old Oct 23, 2002 | 07:35 PM
It's Blue's Avatar
New User
Well it might be because the GENIUS that was driving the car figured that they could just go out and abuse his/her Honda, thinking that since they now have this "racing clutch" it can/will take anything thrown at it. Also let's not forget that he/she more an likely demanded to have such an extreme clutch be put in without fully understanding the full costs of going to that extreme. I know for a fact that my ACT 4puck is not meant to be driven on the street but I did it anyways and I fully understand what may happen to my clutch, flywheel, pressure plate, and all other related components that are attached. If said person did not want any mechanical problems then they should have purchased and installed a stock clutch.Sorry if this upsets you but I was just asking what was the problem with Dietz and not a smarta$$ comment .
Old Oct 24, 2002 | 09:41 AM
Well let's say that some stunna goes in there and needs a clutch replaced... Doesn't know **** about his car but knows that he wants it to go.... Gets a 4 puck installed and his tranny rebuilt.... off he goes.... Then who's fault is it? The stunna for wanting something that will be applicable to future upgrades? or the seller who should have took a moment to ponder just how much HP this car will produce. I'm sure by now you know who this person is, and we all know that NA that car would be mid 200 at best... Type R clutch disk is more than sufficient and more cost effective.
[Modified by advanracing62, 11:51 AM 10/24/2002]
Old Oct 28, 2002 | 06:39 PM
na96gsr's Avatar
New User
Before the word of the days was "puppet master" , now its "stunna"...where are you comming up with these names??? Perhaps you ARE the real/original stunna! When "It's Blue" gets his tranny fixed perhaps you should run him?! If It's Blue is up for the challenge...???
Old Oct 28, 2002 | 06:40 PM
SergEK's Avatar
I see so just because he gets an ITR tranny for a good price from my mechanic I like this Tim = Jealous stunna
BryanPendleton
Feb 8, 2006 12:01 PM
SIC_WIT_IT
Jul 8, 2004 08:21 PM
patdemps
Jul 2, 2003 06:42 PM
under_psi
Jun 24, 2002 09:07 AM
