50 Shot of nitrous????
Old Oct 15, 2002 | 09:16 PM
shift6's Avatar
Default 50 Shot of nitrous????
I have a b18b1 swapped into my 95 civic and i hooked up a Nitrous Express system. I am running 35 shot but want to up it to 50 shot, will this be to much for the stock internals?
Old Oct 15, 2002 | 09:20 PM
JDM88EF9's Avatar
Default Re: 50 Shot of nitrous???? (shift6)
That should be just fine.
Come on people back me up!
Old Oct 15, 2002 | 10:43 PM
TimoneX's Avatar
New User
Default Re: 50 Shot of nitrous???? (JDM88EF9)
I'd back the timing off and richen the mixture a bit. You should be fine though.
zeroracerh's Avatar
ive got your back! it'll do just fine with a 50 shot!
Old Oct 16, 2002 | 12:48 AM
NXSpoon's Avatar
Default Re: 50 Shot of nitrous???? (zeroracerh)
You changed your plugs, right?? These are what you want to run: ngk bkr7e
Do NOT use platinum or Zex plugs. Way too many problems reported and witnessed. Like melted electrodes, insulators, etc.
Old Oct 16, 2002 | 10:17 AM
torr's Avatar
Default Re: 50 Shot of nitrous???? (NXSpoon)
50 shot is fine, go 70 with an ignition and maybe a fuel filter
Old Oct 16, 2002 | 11:14 AM
Brian_92GSR's Avatar
New User
Default Re: 50 Shot of nitrous???? (torr)
Hopefully he is already running a fuel filter.
Old Oct 16, 2002 | 12:30 PM
n2ohuffer's Avatar
Default Re: 50 Shot of nitrous???? (Brian_92GSR)
Spraying 75 to mine with Zex plugs and retarded timing....no probs yet, but motor is mad strong in high RPMs already...
Old Oct 16, 2002 | 12:34 PM
MikeMAN's Avatar
you should be more than safe..
with that engine, i would venture to say 70 would be pretty safe without retarding timing, as long as u are using at least 93 octane gas or higher..
might wanna check out colder plugs tho, and ignition setup if you get really into the n02
good luck with ur setup!,
mike
Old Oct 16, 2002 | 04:54 PM
JDM88EF9's Avatar
Thank you!
Old Oct 16, 2002 | 06:45 PM
xxplosif1's Avatar
I was running a 50 shot with nx and no problems at all. Stock timing with 2 step colder plugs and went tru a few bottles and my b18a took it perfectly. Even nx says that you don't need anything to change with their stage 1 efi (35-50-75 shot) But i'd bump the timing back 2 or 4 degrees with the 75 shot.
happy spraying, nx makes good kit
Old Oct 16, 2002 | 06:52 PM
95c1v1cs1's Avatar
Default Re: 50 Shot of nitrous???? (xxplosif1)
tuning is key!
Old Oct 16, 2002 | 09:02 PM
InevitableRace's Avatar
Old Oct 16, 2002 | 09:08 PM
kinesistech's Avatar
A 50 shot is like buying a lap dance instead of a bj, a tease. I had a 70 shot in a sohc and never had a problem. A 50 shot of laughing gas would make me do just that, laugh at you. Step up to at least 70, dont be a *****. Your engine can hold 100 so what is 70 gonna hurt?
Old Oct 17, 2002 | 03:21 PM
EFing8's Avatar
I was running ZEX 75 shot on my b16a1 CRX all summer last year, went through about 8 bottles. Not 1 problem, actually i melted an electrode once. I was running 4 degrees retarded and 1 stage colder plugs. The only reason i melted it was because i was NECK AND NECK with a 4wd turbo&nitrous DSM, we both went to top speed in 5th on the juice. he beat me by about 2 feet.
Old Oct 17, 2002 | 04:18 PM
xxplosif1's Avatar
Default Re: 50 Shot of nitrous???? (CND_CRX)
hahaha same here! I was racing my friend's b16 hatch and i was winning the race until i melted a plug (LS tranny, top 4th)...scared the **** out of me!
Old Oct 17, 2002 | 04:44 PM
stupidfast's Avatar
ive ran 100 shot several times and didnt have a problem.. but i feel alot safer with the 75 shot and 2 degrees retard.. runs all day long ..
Old Oct 17, 2002 | 04:49 PM
performula's Avatar
From what I understand, NOT all the time, rule of thumb is take your engine's HP, divide it by two (or half, whichever suits you) and you should be able to do that number with stock internals.
I don't know if you can give a 500HP Viper a 250 shot of Nitro, but hey, someone probably does.
silverlude80
Nov 8, 2007 10:13 AM
DA9kid
Jan 1, 2007 04:50 PM
vmsturbo
Aug 21, 2004 06:29 PM
seanb18c1
Jun 26, 2003 05:25 PM
-Dizzy-
Nov 26, 2001 04:53 AM
