very weird problem, need help...
Old Oct 18, 2002 | 10:37 PM
hybrid_KJ's Avatar
Default very weird problem, need help...
A friend of mine has a gsr in a crx, the install was very bad (weld in) and the motor sits pretty crooked. He has a reoccuring problem that his crank pulley bolt and flywheel bolts keep backing out. I tried to fix the crank pulley for him and installed it with a new key and bolt/washer, torqued down plenty hard with an impact gun and the thing still backed out while he was driving a week later and like I said his flywheel also keeps backing out. What is causing this? The motor being a little crooked or a bent/bad crank shaft? Or something else? Any input ideas appreciated.
Thanks
Kevin
Old Oct 19, 2002 | 12:09 AM
miller's Avatar
Default Re: very weird problem, need help... (hybrid_KJ)
it might be caused by the vibration of the motor. is the motor welded to the car?
Old Oct 19, 2002 | 06:12 AM
Chiovnidca's Avatar
Is the slot on the crank for the key torn up? That will cause it to loosen up.
Old Oct 19, 2002 | 11:32 AM
hybrid_KJ's Avatar
Default Re: very weird problem, need help... (Chiovnidca)
Okay, the motor isn't welded to the car just the upper tranny bracket was rewelded to the fram. They used the 94 gsr mounts instead of 90-93 teg so the motor sits bad.
The keyway slot is not screwd up as far as I can tell visually. Everything went together right. Even if the keyway is screwed up that wouldn't explain the flywheel bolts backing out in my mind.
I'm thinking the crank is screwed. Anyone else opinions/ideas?
Old Oct 19, 2002 | 12:41 PM
dwilson's Avatar
have you tried using some lock tite. Just a thought
Old Oct 19, 2002 | 01:55 PM
Chiovnidca's Avatar
So what's coming loose? The crank pulley or flywheel?
Old Oct 19, 2002 | 04:10 PM
94gsr's Avatar
I wouldn't think that the engine sitting crooked would be the only cause of this. I'd think that there must be some excessive vibration going on somewhere. I say get the proper mounts & redo it so that the engine sits right, & go from there. If you don't like that idea, go with the previuosly recommended Loctite.
swindian1991
Feb 16, 2011 05:26 PM
1 sLoW hAtCh
Jun 1, 2008 10:07 AM
dohcgarage@714
Feb 25, 2007 11:42 PM
AnthraxVX
Apr 23, 2006 03:41 PM
SpeedDreamz.com
Oct 25, 2005 07:36 PM
