corrosive bath
Old Oct 16, 2002 | 07:20 AM
CXHatchback's Avatar
Default corrosive bath
Is there something that I could soak my rear lcas in that will break down particles, dirt, and rust? I broke that one bolt off but don't want to break off my other one. Just thinking if I let them soak overnight, they might come off no problem. Any ideas?
Old Oct 16, 2002 | 12:25 PM
Default Re: corrosive bath (CXHatchback)
up
Old Oct 16, 2002 | 01:29 PM
MikeMAN's Avatar
maybe just try some good ol' WD40?
Old Oct 16, 2002 | 04:48 PM
Default Re: corrosive bath (MikeMAN)
Yeah, I would. That or PB Blaster. Problem is they don't sell it by the gallon.
Old Oct 16, 2002 | 06:51 PM
keebler65's Avatar
i've found wd40 is best left as a lubricant. try some liquid wrench or the like
Old Oct 16, 2002 | 09:11 PM
kinesistech's Avatar
Default Re: corrosive bath (keebler65)
Just shoot yourself now. Wd-40 isnt a lubricant at all, where on the can did you read that? Its a rust penetrant/repelant. It will however clean away oil and grease so go ahead and relube everything with it.
Old Oct 17, 2002 | 04:01 PM
vtecmissle's Avatar
Default Re: corrosive bath (kinesistech)
heat with a propane torch to expand contract the metal beyond normal heat range. then cool it with pb blaster or super penetrate or wd 40 it doesnt matter. as the fastener cools it will create a slight vacuum around the end of it and you can visibly see the liquid being sucked in. simple physics let soak overnight and use impact in the morning.
Old Oct 18, 2002 | 07:14 AM
Default Re: corrosive bath (vtecmissle)
Thanks, I think I'll go buy a propane torch and try that.
drtysohc
Mar 11, 2008 07:47 PM
gitrdone
Honda Civic (2001 - 2005)
Jul 9, 2006 03:54 AM
_noname_
Sep 15, 2005 09:19 AM
. o 69 o .
Feb 28, 2004 02:29 PM
Peter K
Apr 6, 2002 01:44 PM
