motor question? funny sounds.
Old Oct 15, 2002 | 04:33 PM
AWD: Jeff's Avatar
Default motor question? funny sounds.
a few days ago, i was driving. N decided to downshift hard to second gear. It grabed pretty hard . I have an action 6 puck clutch. Its a dx hb with a 1.8 vtec. So imo it grabs pretty hard. That night i started to hear a funny noise. The noise only came on somtimes whenever i accelerate. Its been 2 days ever since. The noise i can notice. Im not sure what it is? A friend of mine told me it could be my engine mounts. i have no clue what it is? all i know is that its geting me paranoid. With my lucky lately it could be. Anyone know what esle could it be? the noise only came up when i downshifted that one day. Any info would be greatly appreciated.
Old Oct 15, 2002 | 05:17 PM
Hatchy-Ownzjo0's Avatar
H-T Poker champion
Default Re: motor question? funny sounds. (sohc93hatch)
describe the sound.. is it a clicking.. bumping.. or what? When does it happen.. like when you gas it or when you are staying at a certain speed.. or when you steer a certain way.. we need info here!
Old Oct 15, 2002 | 07:54 PM
AWD: Jeff's Avatar
Default Re: motor question? funny sounds. (Hatchy-Ownzjo0)
well i cant really describe the sound. i know its not my axles. cuz ive already broken a few axles. it only happens when i gas it at low rpms becuz i have other sounds that exists. (ie: i have a bad cat converter) it doesnt makke any sound when im steering. im kinda guessing its my motor mounts. it only happens when im gassing it a bit. it kinda sounds likk when you put your car in reverse and drive backwards, but not as loud as it. a little ringing or rattling. i could be wrong about teh sound. its as best as i can describe.
I started to hear the noise, after i downshifted <U>hard</U>
[Modified by sohc93hatch, 5:03 AM 10/16/2002]
Old Oct 15, 2002 | 08:38 PM
TimoneX's Avatar
New User
Clutch & flywheel chatter perhaps?
Old Oct 15, 2002 | 09:37 PM
AWD: Jeff's Avatar
Default Re: motor question? funny sounds. (TimoneX)
my clutch feels fine, and how would i know if i have a problem with my clutch or flywheel?
Old Oct 15, 2002 | 10:27 PM
TimoneX's Avatar
New User
Well usually a clutch problem is slipping, your revs increase but you don't go anywhere. A clutch that's on it's last legs generally smells bad too, but you're using a 6 puck action clutch...kevlar I assume?
Old Oct 15, 2002 | 10:45 PM
aeolus's Avatar
sounds like it could be your tranny.A bearing must be going bad somewhere.
Old Oct 15, 2002 | 11:08 PM
TimoneX's Avatar
New User
Default Re: motor question? funny sounds. (aeolus)
Could be dozens of things. Did you change the pilot and throwout bearings with the clutch? When was that?
Old Oct 15, 2002 | 11:51 PM
AWD: Jeff's Avatar
please explain more about the bearing? i know cars to a certain extent. how would i have done this? a friend of mine was in the car with me at the time and he said the car jerked hard
Old Oct 16, 2002 | 10:07 AM
93_civic_EX's Avatar
does it only make the noise while in second gear, or in any gear? did u grind it into gear? u say its whining? if so then i also think it could be the bearing(s) inside the tranny. sounds like u really beat rag ur car alot. what else have u managed to break in the past(besides the drive axles)? anyways i agree with the above post and that it more than likely is the bearing(s).
[Modified by 93_civic_EX, 2:09 PM 10/16/2002]
Old Oct 16, 2002 | 01:21 PM
.BULLET.'s Avatar
From: kapalua,los angeles,las vegas, HI,CA,NV, United States
either your mounts or your bearing(s) of your tranny...i did a small search and its possible that it would be the bearing or mounts(most likely)..gimme a call.
Old Oct 16, 2002 | 11:06 PM
AWD: Jeff's Avatar
Default Re: motor question? funny sounds. (93_civic_EX)
it makks the noise in any gear. it just depends on how loud my car gets. i know the tranny grabs hard. well ive broken the axles with a different motor. how much is it to get bearings replaced?
Old Oct 17, 2002 | 08:43 AM
well if it is the mounts. u can find them at discount auto parts from about $50 to $80. i still think its the bearings though and u can get those from discount for about $8 to $30+. if u have a jack u can probly get the mount in urself and hope thats the problem. u should bring it to a mechanic, tell him whats the matter and what u did and he'll do the work and buy the parts for u but it'll cost ya probly a lil over $300. the replacing of the bearings usually isnt an easy job and it takes a while. oh yea and if u do go to a mechanic let him know before hand which motor u have to save him some time....good luck
Old Oct 17, 2002 | 10:54 AM
MikeMAN's Avatar
try leaving it in gear and just punch the gas a couple times...if you feel a bump/hear the sound..it is probably your motor mounts.
also try opening your hood, and then rev up ur engine and see how much ur motor moves..
Old Oct 17, 2002 | 10:01 PM
AWD: Jeff's Avatar
Default Re: motor question? funny sounds. (MikeMAN)
a friend of mine said maybe i need a valve adjustment. i takk it to 8k alot. so any opinions.
ToledoLude
May 5, 2017 06:38 PM
1994PreludeSi
Dec 19, 2007 07:58 AM
azteggi
Jan 5, 2005 02:53 PM
caliprelude3087
Aug 26, 2004 10:02 PM
underpressure02
Feb 28, 2003 12:31 PM
