motor mount bolt question
Old Oct 17, 2002 | 09:59 AM
red96's Avatar
Default motor mount bolt question
ok...i found a 14mm bolt just sitting between the ac compressor and the motor mount...and realized it was one of the bolts that holds the motor mount to the block...i hand tightend it back into place for now, but my question is...how bad is it until i can pull the compressor and fully tighten it? is this causing an oil leak (looks like it was covered in oil)? thanks.-bp
Old Oct 17, 2002 | 10:09 AM
93_civic_EX's Avatar
Default Re: motor mount bolt question (red96)
im pretty sure that wouldnt cause any oil leakage. but u should still get that bolt tightend before u break somthing...
Old Oct 17, 2002 | 10:57 AM
MikeMAN's Avatar
Default Re: motor mount bolt question (93_civic_EX)
you should ACTUALLY replace that bolt, it is a "locking bolt" and when they come out, its time to replace them. I recently had this happen to my rear mount.
good luck!,
mike
Old Oct 17, 2002 | 02:37 PM
Chiovnidca's Avatar
Default Re: motor mount bolt question (MikeMAN)
A locking bolt huh? Do you mean a bolt with thread locking compound on it?
Old Oct 17, 2002 | 02:53 PM
MikeMAN's Avatar
Default Re: motor mount bolt question (Chiovnidca)
no, i don't mean a bolt with locking compound. Like the bolt is useable one time, the first time you screw it in nit will lock itself. I didn't make this up, some guy told me when my bolt came out.
hope ya figure it out! (in the meantime some locking compound would probably work just fine!)
mike
Mike Husted
Honda Civic (2001 - 2005)
Aug 7, 2013 02:48 PM
george34
13
Feb 22, 2006 11:09 AM
mkazm83
Jan 28, 2006 04:46 PM
DMF
Oct 13, 2003 06:25 AM
MikeMAN
Oct 9, 2002 06:06 PM
