cel problem
Old Oct 19, 2002 | 08:37 AM
3rdGteg's Avatar
Default cel problem
No help in hybrid or itr section....I knew I should've posted here in the first place...
When I plugged up my obd2-obd1 harness w/ my mugen p28, I get the cel flashing code 8 constantly while I'm driving--constantly, all day long (service connector is not even plugged in and it's throwing the code). Any ideas?
Also recently added a code 1 to that too (service connector is not plugged and it's flashing for as long as the car is on--constant). I know exactly what those codes are but it's not supposed to do that, because ther's no check engine light with my regular obd2 setup at all.
Any help/suggestions will be appreciated, thanks.
Old Oct 19, 2002 | 06:29 PM
3rdGteg's Avatar
Default Re: cel problem (3rdGteg)
Anyone?
Old Oct 20, 2002 | 05:37 PM
3rdGteg's Avatar
Old Oct 22, 2002 | 12:28 PM
3rdGteg's Avatar
bump
Old Oct 22, 2002 | 11:45 PM
enozirt's Avatar
ecm/pcm problem
Old Oct 23, 2002 | 09:32 AM
3rdGteg's Avatar
Default Re: cel problem (enozirt)
ecm/pcm problem
I checked the ecu on a friends car and no check engine light so the ecu must be fine. Any other ideas?
Dead CIVIC
Jul 28, 2009 07:17 PM
Speed94
Nov 6, 2006 06:35 PM
3rdGteg
Oct 18, 2002 08:48 PM
S13 slide
Oct 8, 2002 01:23 PM
