Type R Intake Manifold
Old Oct 19, 2002 | 04:35 AM
7rrivera7's Avatar
Default Type R Intake Manifold
Installed on a first gen B16a and having problems with idle control. Been told I need a Type R idle control sensor.
Can someone tell me where I can buy one since I'm Puerto Rico and I think it is not a available in the US?
Thanks!
Raul
Old Oct 19, 2002 | 11:46 AM
Katman's Avatar
Default Re: Type R Intake Manifold (7rrivera7)
Thanks!
Raul
Yes, you'll need the IACV either from a 92-95 civic Si/EX, 96+ EX, or 94+ Integra LS. The bolt pattern on the 89-91 B16A IACV is too far apart...when it should be closer together as seen in this pic..
[Modified by Katman, 12:47 PM 10/19/2002]
Old Oct 19, 2002 | 03:28 PM
7rrivera7's Avatar
Default Re: Type R Intake Manifold (Katman)
Hey thanks for the detailed reply! What does IACV stand for - Idle Air Control Valve?
Raul
Old Oct 19, 2002 | 04:01 PM
Jesse H's Avatar
Raul
Yessir. I plan on eliminating mine.
Old Oct 19, 2002 | 06:13 PM
7rrivera7's Avatar
Default Re: Type R Intake Manifold (Jesse H)
Can you give more info? Is this not necessary? Why would you want to eliminate it?
Old Oct 19, 2002 | 06:16 PM
7rrivera7's Avatar
Can I buy yours?
Old Oct 19, 2002 | 06:35 PM
3rdGteg's Avatar
How do u eliminate it? I'd like to know how too.
Jesse H's Avatar
Sorry, bad choice of words on my part. I'm bypassing mine...trying to elminate all the sources of hot coolant to my manifold. It will still be on the manifold, plugged in, just no coolant will be flowing through it.
Old Oct 19, 2002 | 08:21 PM
3rdGteg's Avatar
wouldn't it throw a code then? Let us know if it works.
Old Oct 19, 2002 | 09:08 PM
Jesse H's Avatar
Default Re: Type R Intake Manifold (3rdGteg)
No codes as long as it's plugged in. I live in warm Houston so I don't worry much about that or the throttle body getting coolant.
Thanks for the tips Steve.
Old Oct 21, 2002 | 12:42 PM
Katman's Avatar
yep same here.
Since I don't live in a cold climate zone (snowy place), I bypass the coolant going through the IACV also. I just have the sensor plugged into it...everything runs fine.
Old Oct 21, 2002 | 03:23 PM
civicguy's Avatar
yo,boricua!
Old Oct 21, 2002 | 05:05 PM
S13 slide's Avatar
how do you bypass it?
Old Oct 21, 2002 | 05:15 PM
rainmanEK's Avatar
big strong guy
Default Re: Type R Intake Manifold (S13 slide)
ditto!!! florida is mighty hott!!! eric
Old Oct 21, 2002 | 06:59 PM
3rdGteg's Avatar
Default Re: Type R Intake Manifold (rainmanEK)
How? Somebody tell us please.
Old Oct 21, 2002 | 07:15 PM
Katman's Avatar
its easy..
you have 2 options.
1) you can try and reroute the coolant lines back to the coolant pipe that runs across the back of the block
or
2) completely plug off the coolant line. Put some kinda plug (bolt with hose clamp comes to mind), so coolant doesn't squirt/pour out of it.
Its not hard at all.....
just look at how the coolant lines are. They're all recirculating coolant with each other and the main line is the big coolant bar that runs across the back of the block.
hope this doesn't sound to confusing...lol.
Old Oct 21, 2002 | 09:15 PM
FitCRX's Avatar
what bout on a skunk2 manifold on a b16...my IACV fit...but I had to by pass Fast idle control valve. I don't even know if thats what its called. its located below the throttle body bolted to mani....has coolant running threw it. Can't get the cars idle below 2k....is this the problem..if so what can I do?
Old Oct 21, 2002 | 09:47 PM
3rdGteg's Avatar
Default Re: Type R Intake Manifold (FitCRX)
Thanks Katman!
Old Oct 22, 2002 | 01:07 AM
Lyonel's Avatar
I wrote a little how-to on a ITR IM install on a 1st gen. B16a. There's a link on there about TB coolant bypass as well. http://homepages.paradise.net.nz/asmsbm/r_iminstall.htm
roninzane
Jan 25, 2007 06:40 PM
2000Accord5sp
Dec 18, 2003 06:57 PM
raene
Aug 7, 2002 12:20 PM
