WTF, VSS code...?
Old Oct 15, 2002 | 11:22 PM
raene's Avatar
Default WTF, VSS code...?
Got a code 17 driving to work today in traffic. Doing no more than 20mph. Got to work, and after work drove home. No VSS code.
Does this sound like a bad connection somewhere? Or maybe my speedo cable could cause it (the speedo needle currently wobbles)?
Old Oct 16, 2002 | 05:57 AM
satan_srv's Avatar
Default Re: WTF, VSS code...? (raene)
Low power steering fluid?
Old Oct 16, 2002 | 06:02 AM
EP3_05's Avatar
Make sure your Speedo cable is snuggly connected at both ends.
Old Oct 16, 2002 | 08:42 AM
raene's Avatar
Default Re: WTF, VSS code...? (91civic)
Thanks, I'll check that!
I don't have power steering (it's in a CRX)
[Modified by raene, 9:42 AM 10/16/2002]
Old Oct 16, 2002 | 09:09 AM
satan_srv's Avatar
doh...prelude VSS runs with PS fluid
Old Oct 16, 2002 | 11:13 AM
Brian_92GSR's Avatar
New User
Default Re: WTF, VSS code...? (satan_srv)
But the VSS has nothing to do with the power steering. The fluid runs through it only for the aid of the power steering rack.
If the speedometer is working than the VSS code shouldn't come on. Did you notice if it was working or not?
Old Oct 16, 2002 | 11:37 AM
satan_srv's Avatar
Default Re: WTF, VSS code...? (Brian_92GSR)
4th gen VTEC Power Steering is Speed dependant so the VSS on the prelude does have something to do with the PS
Old Oct 17, 2002 | 11:01 AM
raene's Avatar
Yes, the speedo works... I recently changed my gauge cluster over to an '89 cluster, and now this code appears (and this also explains why frickin' VTEC wasn't working at the track last Friday).
I'm going to swap back to the old cluster today and test it, then swap to the new cluster, and see if I can troubleshoot... the new cluster is so much nicer, I don't want to lose it
Stefffff
Jul 25, 2014 11:56 AM
mrtickel
Dec 15, 2011 11:10 AM
DANINE101
Mar 4, 2010 09:41 AM
Johnny_Rocket
Oct 18, 2005 07:55 PM
