Suspension Lowering Question
Old Oct 16, 2002 | 03:21 PM
ayacht's Avatar
Default Suspension Lowering Question
If I had lowered my car 1.75" and found it to be to low, is there a product, such as a spacer, to regain 1/2" of hieght, either between the perch&spring or tower&mount?
Old Oct 16, 2002 | 04:10 PM
LuderCriS's Avatar
Default Re: Suspension Lowering Question (ayacht)
did u put your bumpstop back?
Old Oct 17, 2002 | 07:57 AM
ayacht's Avatar
Default Re: Suspension Lowering Question (chanluder)
This is a question of whether or not the car can be raised slightly after installing lowering springs by installing a spacer, thus giving a 1.25" drop in stead of 1.75". In the case were the owner believed the drop was a bit too much. Nothing to do with the bump stop rubber.
Old Oct 17, 2002 | 09:48 AM
93_civic_EX's Avatar
yes, u can buy spacers or a lift kit at most local auto part stores if u found the 1.75" too much and want to lift it a half an inch....a half inch isnt going to be much though....next time u should research on what springs ur going to buy to see if u'll like the amount of drop....it'll be really stiff after the lift, hope u like it
Old Oct 17, 2002 | 12:35 PM
ayacht's Avatar
Default Re: Suspension Lowering Question (93_civic_EX)
It will not be stiffer, unless you missunderstand what a spacer does. Icrease perch hieght does nothing to change rate or ride, it merely lifts the car. I know they have spacers for lifted vehicles, I was just asking if anyone has seen small variance spacers, or a shim if you will, that would sit on the spring perch.
mrpoker
Jun 19, 2010 07:34 AM
obuhmyuh
May 5, 2008 02:42 PM
migizzel
Aug 26, 2005 06:27 PM
98itR484
Apr 25, 2002 09:21 PM
TQ
Apr 22, 2002 12:39 AM
